Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
Front panel flashes like a christmans tree and does not run. only runs occasionally
  • Anonymous Dec 22, 2007
    Lights on the control panel of my Kenmore dishwasher 15173400 are all flashing. Call the repair center I bought it from. They said to try to reboot, by turning the power source for five minutes. Well lights went out but came back on while starting a new washing cycle. Is this a major mother board
    repair? Or is there some simple fix a do- it- yourself can tackle.
This sounds like a control board issue to me, possibly the board connected to the display panel.
Posted on Oct 12, 2007
SOURCE:
My 3 arc fault breakers run hot and draw about a third of an amp from the ground bar wire each, 24/7. Is this possibly normal?
How did check amps. I would check the amps on the circuit itself. Might be drawing close to max. thats why it's hotter. breaker should have no more than 80%. Of an amp draw on the circuit
Oct 05, 2016 | Eaton ARC FAULT CIRC BREAKER
Tree diagram...is there a threaded tube running between the two parts of the tree on the front end?
There is the steer tube that is pressed into the lower tree/clamp. This tube is threaded on the top so that you can put a nut on it after the upper tree/clamp to preload the headset when you install the front end.
Oct 05, 2013 | Honda CB 750F2 Seven Fifty Motorcycles
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a Lionel 2055 post war train that I have not used in many years. I am setting it up around the Xmas tree. It ran well on the carpet when I tested it out but not around the tree on the hardwood...
Check to see if you picked up any fibers on the wheels or axles from your carpet running. Also check to be sure the pilot truck can swing freely from side to side and is not bent. There is also a light coil spring on the front truck pivot pin. Be sure that the spring is there and is not damaged. Another thing to check is the drawbar between the locomotive and tender. Your front wheels may be getting lifted off the track because the rear of the locomotive is getting pressed down. This a soft carpet may compensate for this but not a hard surface. Run your train at a speed where it derails and look closely at the locomotive to see if the rear is being pressed down.
May 23, 2017 | Lionel Toys
Cannon BGE 3000 petrol generator runs for about 10-20 minutes then cuts out. Just occasionally it doesn't quite cut out, but will get going again without me having to start it.
hi i have a BGE 3000 petrol generator it was working 1 min and stop the next it runs well but there is no power going to the panel on the front any help? thanks
Mar 17, 2010 | Cannon Electrical Supplies
1990 accord rpms run high seems to be stuck in sport mode,red dash light are flashing like a christmas tree, speedometer does'nt work, now im needing to get a jump.
You need a new transmission computer. They are a very common failure part, google: "honda tcm". It is located under the front passenger's floor board. Buy a new one off ebay or a rebuilder, not used, they are all bad.
Jan 28, 2010 | 1990 Honda Accord
Gas heater short cycles
At your indoor unit, look at 1 of the front panels and see if there is a clear, plastic view port. Look through it and try to see a red flashing led. Count the flashes and look at the factory data on the front of the unit. That should give us a trouble code and lead us in the right direction. Also make sure air filters are clean.
Aug 25, 2017 | Honeywell Electronic Programmable...
I recently had an a/c belt break on my 2000 Sienna Van.It was replaced and the new belt continues to squeal.It has been adjusted several times and then replaced but squealing continues. I have discovered...
get away from the shade tree. have your a/c pressures checked. the compressor may be on its way out. make sure the cooling fan or fans are working. did you use a quality belt, or some cheap brand from otto zown? if the rear a/c is running but not the front, the a/c compressor is not engaged, thats why is doesnt squeal.
Sep 27, 2009 | 2004 Toyota Sienna
Tv turns on for about 1 minute then turns off by itself
could be the lamp. It is consumer replacable.
Aug 10, 2009 | Televison & Video
Model 1100 WIL 113
sounds like you may have some moisture getting into the electronic panel but because it only happens rarely best not to try to fix. This is normally quite expensive as they need to replace electronic panel and seals around panel, so I would live with it.
Dec 13, 2017 | Indesit W 123 Front Load Washer
Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
71 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
