Question about Frigidaire Refrigerators
Refrigerator not working freezer is like fridge
  • beyeore83 May 11, 2009
    no frost build up in freezer. no water into the fridge. yes the fan in running in the freezer
    Thank You
    Sergeant:
    Champion:
  • 214 Answers
Need more info is there frost buld up in freezer?or water leaking into fridge compartment?Is the fan running in freezer part?
Posted on May 10, 2009
  • tom wright
    tom wright May 11, 2009
    If your fan is running and there is no frost then you may have a faulty start relay on your compressor I would remove it and shake it if it sounds like burnt parts moving around in the relay you need a new relay.Other then that you may have a seal system leak hope i helped :)
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Freezer works fridge does not
Needs to be completely thawed for 2 days. Or wlse the circulator fan under the freezer panel inside freezer is not working. Take the plastic bottom of freezer out and let thaw. Then plug in fridge and check if the fan is running inside there. Do not poke around inside there or fridge will be punctured and ruined.
Jan 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
In my candy fridge freezer the freezer is working ok but the fridge isn't working at all. Please advise
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Candy CPCA240FFK Bottom Freezer...
Freezer working fridge not
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
5gf
Jul 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
Bottom Freezer Refrigerator: Freezer is working, fridge is not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 01, 2009 | Refrigerators
Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
might sound stupid but is the fridge controled by a separate thermostat inside the fridge
Jun 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
74 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
