Question about Delta TS200LS Shopmaster 10 Inch Portable Bench Saw With Legs
I hear the motor turning but the blade does not turn
The motor is working but it seems that the jackshaft assembly (http://images.toolpartsdirect.com/schematics/delta/ts200ls.big.pdf part 326) is broken. I took apart the motor and unscrewed the jackshaft assembly. The part that gets turned by the motor does not turn the part of the shaft that the blade gets mounted on. does it mean that this part is broken or is there a different problem? I can upload pictures if needed.
  • ell_sam May 10, 2009
    there is a snap ring but it is very tight. do I need a special tool to remove it?
  • ell_sam May 11, 2009
    is there a standard woodruff key or are there different sizes? I ordered a snap ring pliers and was wondering if I would be able to replace the woodruff key. There is no part number for it on the exploded parts list for my saw. The saw originally cost under $100 new so I dont want to spend $35-40 on a part. thanks.
  • 5,660 Answers
The jackshaft assembly is broken. The blade mounts to it, and it mounts to the motor shaft. Is there an internal snap ring, you can remove from the jackshaft assembly, to disassemble it? I believe there is a woodruff key inside. It may be that the hub of the jackshaft assemblies keyway, is broken, or perhaps the key itself.
A woodruff key is halfmoon shaped.
http://www.google.com/imgres?imgurl=http://upload.wikimedia.org/wikipedia/en/1/1f/Woodruff2.png&imgrefurl=http://en.wikipedia.org/wiki/Woodruff_key&h=326&w=300&sz=86&tbnid=zLKZ-U_RG0gA0M::&tbnh=118&tbnw=109&prev=/images%3Fq%3DWoodruff%2Bkey&hl=en&usg=__VhyoedtqViZ6lNCTLRzkx3LapfY=&ei=fF0GSoewD5GsMubPpKMD&sa=X&oi=image_result&resnum=4&ct=image
(You can click right on the images, to enlargen them)
Posted on May 10, 2009
  • joecoolvette
    joecoolvette May 10, 2009
    There are different styles of snap rings. External and internal, and different shapes. The type you're addressing will be an internal snap ring. Some have a circular shape on each end with a hole. (Hole in each end)
    1.Example:http://www.spikewheel.com/images/spikewh...
    For this type you use snap ring pliers. The pliers has a peg on each jaw, that fits into each hole. When you squeeze the pliers handle's together, it compresses the snap ring, where it can be removed from the groove it's in.
    Example:http://www.amazon.com/Grizzly-G8069-Circ...
    Some, are just a ring shaped piece of metal, that has a tapered end, and this tapered end overlaps.
    Example:http://www.directindustry.com/prod/small... (If this page doesn't come up directly on my example, go down to -> Spiral Retaing Ring - Spirolox, and click on it)
    This type is a little harder to remove, takes some finesse, and one has to watch one's fingers, when removing it. You have to get one end started away from the groove, while simultaneously easing the snap ring up, and out.
    I use a scratch awl to ease behind the edge of one end. Ease it out a little bit, then try to force a small thin flat tip screwdriver, behind this edge. Then you keep working the edge up and out of the groove, while sliding the thin flat tip screwdriver, behind the snap ring.
    Sometimes it's no fun, and using a sharp pointed scratch awl, plus a thin flat tipped screwdriver, you can slip. Hence the statement to watch your fingers. Also sometimes the snap ring likes to slide around, moving away from you. Just gives you a warm fuzzy feeling all over.
Remington Hedge Wizard - driver/oscillator assembly broken - motor turns blades do not oscuillate
Hello There, blades oscillating are usually controlled by the motor. When the motor is rolling then the fan not oscillating is usually a minor problem. Usually the blades are connected to the motor using a rod which is directly connected to the blades.
If the oscillator assembly is faulty this could need replacement of a part. And this would require expert help. Which part exactly is broken? How well can you handle mechanical assembly parts? i could try to get you an assembly guide to help determine which part is faulty exactly but i need to know the above.
Hoping to hear from you soonest.
Thank you for visiting FixYa.
Aug 01, 2011 | Remington Garden
Was mowing the lawn the other day, when over some thicker grass and it shut off. When I pull the starter cord it gets stuck; the flywheel won't turn. I checked the ratchet pawls and they seem to be fine....
Unless some tough grass blades got wrapped around the blade spindle (which would stop the blade from turning anyway) the motor probably just stalled because it wasn't powerful enough to shred up the thicker grass so that, in itself, may not be directly related to the problem you are experiencing. These mowers are relatively simple creatures so there are not many things to go wrong. If you lay the mower on its side and rotate the blade by hand you should be able to see the flywheel turning through the air intakes on top of the mower. If the blade is turning but the flywheel isn't it would seem to indicate that something has sheared off in between the two and/or the engine has seized up. As you turn the blade can you hear the piston sucking and blowing? If you can then the engine has not seized and the problem lies in the flywheel assembly.
Jan 30, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Blade does not move when turned on
Try spraying the blade assembly with a good rust remover like PB Blaster or even WD 40. Might be something is rusted and won't let blades move. When you are done trimming reapply some oil to displace any water that comes out of whatever you are trimming.
Good luck
roundo4
Aug 09, 2009 | Black & Decker Hedge Trimmer
Fan will not spin unless kick-started
The bearings are dry. They are not really made to re oil. You can try...Try to take the ends off and get some 3 in1 oil in. That's all it needs
Jul 21, 2009 | Dryers
Can you tell me what is causing my delta mitre saw motor to run but the blade does not spin powerful enough to cut moulding?
Maybe the bolt which holds the blade on is loose. If the motor is on the RIGHT side of the blade, then the bolt has 'left-hand' thread. Turn it counter-clockwise to tighten.
Jun 19, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
May 09, 2009 | KitchenAid Food Processors
Replaced starter gear then torqued to 5 lbs,fired up,fine? replaced primary and now wont start?
Well, first off....Dont try starting it anymore without the primary, it can damage the gears. The problem you describe is common with custom builds. I'll assume you purchased the correct stock jackshaft for your model and installed the lock plate and everything else correctly. You can tighten the jackshaft bolt to 7-9lbs. Your last step is putting a wrench on the assembly and pulling it out and turning 1/4 turns to make sure its not binding, as a last resort you can bevel the jackshaft bushing on the out primary so it goes in smoothly - thats what I did on mine and it works like a charm. Good luck
Oct 27, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Blade not turning
the top rubber piece could be worn enough that it is not engaging the pitcher. look at it carefully and see if the "teeth" of the rubber disc on top of the base has not cracked and worn away. a picture of the new one can be seen on the parts websites to compare I spent $10.00 for my replacement but i found them at other sites for $6.00. you will need a very skinny 7mm open ended wrench to get the old one off and it is left handed threads that means clockwise will loosen not tighten the part.i ground down my wrench but an ignition wrench from an auto store will usually be thin enough to reach the flats on the shaft under the rubber disc
Feb 21, 2008 | KitchenAid KSB3 Classic Work Top Blender
Delta TS200LS Shopmaster 10 Inch Portable Bench Saw With Legs Logo
274 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
