Question about GE WBSR3140DW Top Load Washer
Washer Drum I had to replace a holes under my washer, when I turned it back over the drum was not level, how can I fix that?
  • 100 Answers
The washer tub is supported by 4 shocks and the mounts for those shocks adjusted when you tipped your washer
Posted on Oct 30, 2007
SOURCE:
My washer will not spin and acts like the inner drum with holes is stuck, what is wrong?
One of two reasons: The drum belt has broken and needs replacement, or TWO, check for an object that may have accidently jammed the drum from turning; such as a sock falling into the tract where the drum rotates, or a bad seal. Check the drum for movement by hand, and see if you can free it up manually. Last: check alignment. Look for damaged fittings.
Feb 04, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
When i load my washer drum in washer will not agitate or spin off tract.
if noisy like plane taking off bearings gone check play on drum by pushing drum back and forth look for large gap between drum and door seal and listen for scratching noise when turning also some machines wont spin if the load is uneven
Dec 12, 2014 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
Hello. My Kenmore 80 Series/ Heavy Duty(Model # 110.24852300) is shaking like crazy during it's spin cycles. I've been doing research online about this. I will proceed in turning it over and searching for...
It is not recommended to turn the washer over, or on it's side. These top loaders have a direct-drive gearcase that is filled with oil. Laying the washer down can cause oil to leak from the breather hole on top of the gearcase unit.
I would recommend you check the level of the washer before doing anything else. These model washers have an auto level system on the back two feet, followed by a manual level on the front two feet. The following link explains this leveling system and how to properly level the washer:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
An unlevel washer is the number one cause of off balance issues and vibration.
If you do wish to view the washer internal components, the correct way of accessing the interior is to remove the exterior washer case. This procedure is not difficult. The following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
Other causes of vibration (if the washer is level):
1. Loose suspension springs on the lower support under the drum.
2. Loose agitator bolt causing the agitator spin unbalanced.
3. Loose spanner nut under the agitator causing the wash tub to be loose.
4. Suspension pads under the drum worn out and requiring replacment.
You can view exploded view diagrams of your washer at any of the following websites to assist you with your inspection:
searspartsdirect.com
pcappliancepartspros.com
Refer the "Washer Base" drawing for a view of the suspension components. Refer to the "Agitator" parts list for a view of the agitator components.
If you need further assistance, please let me know. I hope you find this information helpful.
May 04, 2011 | Washing Machines
I have a whirlpool washer lxr7144e01 the water drains out but it wont spin. It looks like the drum is not sitting level anymore. You can hear something runing under the drum.
the drum support spring/s have come off,,letting the drum drop a few inches,,take the top or back off and the support springs can be put back on or new ones fitted,,the springs fit into the top of the washer case and hook onto the drum
Jun 28, 2010 | Washing Machines
We just replaced the struts because the washer is making such a horrible noise when it spins. That didn't fix the problem. I sounds like it is inside the drum............at a loss as to what to do now. ...
there are leveling feet under the front of the washer...lift front of washer and these feet should turn like a screw to level the washer....unlevel washers make terrible annoying noises...i hope this helps..good luck
Jan 03, 2010 | GE WSXH208A Front Load Washer
Water pouring out from under my washer as it fills...
hello mam please check the rubber sleeve of the drum if there is any crack it should be replaced and check the drum if there is any holes in it, so please call the engineer and make him to check these.
Sep 29, 2009 | Washing Machines
Drum wont turn
sounds to me like the belt may have fallen off the back of the drum.
look under the lid and see. if a wd, should be simple enoughto put it back on by removing the back cover to refit.
turn the power off though.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Object in the drum
this aint an easy fix.
Sometimes a bra wire gets through the holes and gets stuck.
the only thing you can do is split the drum housing and empty it out.
No hard to to but takes a lot of time and patience.
Sometimes when you are lucky take the pump hose off the drum housing and look in that hole. sometimes it gets stuck there
Mar 04, 2008 | GE WSXH208A Front Load Washer
GE WBSR3140DW Top Load Washer Logo
53 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
