Question about Optics
E-bino cam x1 8008 vga drive for vista. please thank you
  • 4 more comments
  • eduardo freitas May 11, 2009
    I bought the internet for 3 years. I know it in xp, but now I have seen and want to install it always "error" and says not enough memory to install, which is not true
    I bought the internet for 3 years. I know it in xp, but now I have vista and want to install it always "error" and says not enough memory to install, which is not true
    have Windows Vista and am trying to install a "DIGITECH" 4 in 1 (eB1030) Digital Camera Binoculars. The software disc is labeled "e-BinoCam. The problem I am having is that when I try to install this I get the message "Unable to read version information from the file C:\Program Files (x86)\Ulead Systems\Ulead photo Explorer 7.0\Pex.exe. Insufficient memory or system resources low." I have tried several times uninstalling and reinstalling. I cannot believe that I have Insufficient memory or low system resources. This is a Gateway m-series laptop 64 bit 3 gig ram and 268 gig hard drive computer new in August of last year. I tried to open the driver for this right from the CD but windows says it cannot find the driver. I am unable to find the driver on line. Can anyone PLEASE HELP ME figure out how to get this working or know of where I can download the driver?
    I have Vista no XP and mor of 10 GB
  • 10,515 Answers
Problem - Less RAM ( Random Access Memory ).
Go to Desktop Icons>Right Click My Computer>Properties.
Check RAM - It would be 128,256 or 512MB which is Quite Less as per Latest Standard.
If you have Less RAM, you cannot install a software that consumes more RAM as it would result in crashing of windows XP.That's a feature of Windows Xp.
Permanent solution - Increase RAM.Go to 1Gb.
Trick that might work :-
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
Last option - System restore which is not advisable as you would lose data which you have store after the default system point.
Any further help, let me know.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 11, 2009
  • taran_2005
    taran_2005 May 11, 2009
    Do use the trick - That's the best way if you have more than 1Gb Ram.
    Thanks.
  • taran_2005
    I got that..Still you need to increase Virtual Memory to allocate more space to the o/s platform.
    Follow and then tell me whether it resolved the issue or not....
    n Windows XP
    7.Click Set
    Special Note:
    HOT TIP:
    to 1.5*512= 768
    Thanks.
    President:
  • 1,197 Answers
Hi ..... i dont think e-bino cam is vista compatible......
source: http://www.fixya.com/support/t1689417-driver_e_binocam_in_windows_vista_work
tough luck
have a nice day
  • 13,433 Answers
Whats the brand and model, what year is it made?
  • Ekse May 11, 2009
    can you tell me what the brand and model of that is?
  • Ekse May 11, 2009
    You can try right clicking on the file and select Run As Administrator.
Sony vaio VGN-SZ430N/B
I'd suggest ring back Sony support and tell them that your OS is Windows 7 - not Vista. Therefore, you need the upgraded VGA driver because the Vista driver is incompatible with Windows 7. Hope it all goes well. If my suggestion works for you, please do rate me. Thanks
Feb 04, 2010 | Sony VAIO Notebook
Need a download for gigaware web cam 25-234
http://support.radioshack.com/soft.htm
VGA 25- 234 pre Vista
http://www.radioshack.com/search/softwareResults.jsp?sr=1&kw=25-234&origkw=25-234&kwCatId=&hideBackToAll=true
VGA 25-234 Vista
Feb 02, 2010 | Radio Shack VGA PC Camera Webcam
New hdw s/w cannot find Drivers for 25-157????
If you are running XP or Vista, unplug the cam from the computer and after shutting down the computer, reconnect the cam and reboot the puta. The "Found New Hardware" wizard should start, it may say cannot find drivers, reinsert your install CD then point to that area for windows to search(Drive D or E) and you should be all set.
Aug 20, 2009 | Radio Shack VGA PC Camera Webcam
Perdi o meu cd de intalacion
Vale, vaner...
parece que el driver es demasiado antiguo para funcionar con windows vista, necesitas bajar el controlador para vista... lo puedes encontrar en esta página en el web de Radio Shack: Radio Shack vga pc camera
si en la foto del Gigaware cam ves el cam que tienes... mira en la lista de la izquierda y pincha en 'Software Downloads' alli encontraras 3 opciones para bajar... la segunda opción es para vista... eso lo puedes ver cuando pases el cursor por encima del enlace...
espero que eso te soluciona el problema!
bru*
Feb 03, 2009 | Computers & Internet
Windows vista does not accept vga and sound driver
download driver ''R145551.exe'' and install it for audio device to work. you can download this by typing the r145551.exe on google search for more details contact me salman90@live.co.uk
Sep 15, 2008 | Dell Optiplex GX280 (99301) Motherboard
Please tell me how to install Gigaware PC Cam on my Vista Computer?
This might help, then again it might not. It seems that your comments are well founded regarding this particular cam. Suggestion is either take it back for refund or give the driver below a try. No guarantees provided.
http://www.esnips.com/web/CIFSingleChip
Jan 18, 2008 | Radio Shack VGA PC Camera Webcam
My starter disc
You posted in hp personal vga web camera:
http://tinyurl.com/3ahkyg Choose your operating system and download the software.
But in the body you say chicony:
http://www.chicony.com.tw/download/kb/top1.asp
Depending on which cam you have one of the two links
will get you the software.
Jan 12, 2008 | HP VGA Webcam
Optics Logo
198 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
