Question about Panasonic Portable Radio/Cassette Player
Tascam porta one play transport system won't stay in play position,stops within seconds.Capstan moving,all other functions seem fine.
Hello.My problem is with my tascam porta one.I have a small studio,and I decided to turn on and use my porta one tonight,and it hasn't been used for some time,but the play transport won't stay in the play position.It wants to stop constantly.Rewind and fast forward,and all other things seem to work fine.I know years ago,it would occassionaly lock up,so I was told by a music store to take the back off,and turn this big wheel clockwise,till it clicks.That's when the play transport locked up,but now it won't even stay in the play position at all.The capstan is moving,if that's of any help.Thanks Sharron
5 Suggested Answers
vcrdr1
  • 53 Answers
SOURCE: vcr plays ok, but will not rew or ff
either bad mode select switch or bad sensors. my bet would be bad mode switch( pull apart and clean contacts.)
Posted on Mar 13, 2007
issy2
  • 462 Answers
SOURCE: replacing capstan and flywheel belts- tascam 244
Surely you can take it to any electronics repair shop and get it replaced, also they will tell u the necessary replacemnts to be done. All the best.
Thankyou...!!!
Posted on Feb 10, 2008
Grubhead
  • 5391 Answers
SOURCE: 1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Posted on Dec 22, 2009
annabanana66
SOURCE: put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
Posted on May 11, 2012
Tascam 238 recording deck will not stop rewinding.
Are you any good at surface mount circuit board repair? It seems that the caps go bad. Check out this: http://www.thegreatbear.net/audio-transfer/8-track-cassette-capstan-motor-tascam-238-syncaset/
Jun 08, 2014 | Tascam 2488 Portastudio Multitrack...
Tascam 122MkIII has flashing lights, does not run.
The problem is a lack of movement in the transport to tell the controller that it has completed it cycle. This is most of the time caused by the grease they used and sometimes a gear with broken teeth on it. These gears have been discontinued and I am having some made but it will take a few months to set up. I do have some in stock right now for repairs. The transport will need to be cleaned of old grease and new grease put into it. They also suffer from decaying capstan surface mount caps. These are replaced when I do the gear correction. After that they are good decks.
Jan 28, 2014 | Tascam 122MKIII Single Dual Cassette Deck
Tascam 122MKIII Cassette player/recorder is malfunctioning.
I have one here at my shop that does the same thing almost. I found a gear broken in the mechanism system. The flashing LEDs tells you that the system control IC can not get the transport where it is suppose to go. The Gear C as described in the manual was the problem in the deck here. The head base was in the up position in this unit and thus would not eject. My E mail is skywavebe@sbcglobal.net. Due to the amount of dis-assembly to get to the transport control section this might be a job for a technician.
Feb 22, 2013 | Tascam Audio Players & Recorders
I have a Teac A-6300 that won't go fast forward or reverse but the capstan motor is running
The Capstan motor is just for the play speed regulation so it has nothing to do with the reel motors. You can have an open safety microswitch or maybe a bad relay. It is really hard to say without looking at the unit but I am sure it is repairable. Is the right dummy plug put in the back? This can stop all transport functions if it is out.
Apr 14, 2012 | Teac Audio Players & Recorders
Tape heads are stuck will not disengage. transport will rew and fast forward but will not play or record. also could not eject tape. unit is a tascam porta one mini studio.
There is a cam system in the transport and they need to be lubricated. It might cost more than $100 to fix. Sometimes the gears have rounded off teeth that you can not get anymore.
Sep 24, 2011 | Tascam 302MKII Single Cassette Deck
The auto stop mechanism seems to have completely stopped working. When play a cassette, it eats it. When you put the deck into play mode without a cassette and push on the pinch roller with your finger, it...
When's the last time it was cleaned? It surely needs it now.
Never touch the any part of the transport that directly contacts the tape with bear fingers.
This sounds like a failure of the take-up (left) reel to take up slack as it's fed in by the capstan.
You can probably trust the machine to fast forward or rewind a tape to test the ability of the reels to manage slack since either action only requires one reel to pull while the other just coasts. Failure would look like stationary tape that eventually would time out and reset the command.
If it won't do fast transport motions that eliminates the capstan/pinch roller.
If it CAN FF and REW then the capstan, pinch roller, heads or something is probably glommed up with sticky tape oxide, which brings us back to the first question.
Jun 30, 2011 | Panasonic RX-FS470 Cassette Boombox
Stuck tape in Tascam Porta One
It sounds like the rubber belt drive may have broken and tangeled in the drive mechanism. If you are confident you can disassemble it far enough to see if thats what happened. You can still obtain replacement belts. If not from Tascam, then try a good electronics store. Take the belt in and they can help you match it up. Thers also a possibility that your pause mechanism id stuck.
Apr 21, 2009 | Audio Players & Recorders
Transport door stuck, suspect tape wound about capstan.
Open the unit and try to turn the capstan whell with a tip to release the heads and the door locks.
Mar 08, 2009 | Tascam 202MKIII Single Dual Cassette Deck
Tascam model 112
The 112 unit uses a cam operated transport- it may need a new 6.5" belt and some head base lubrication as well as the feedback pot spray cleaned. I do them all the time.
Jul 26, 2017 | Tascam 122MKIII Single Dual Cassette Deck
Transport STOP Button
switches are sealed, need replacement. faders can be cleaned, use de-oxit, good stuff!
Jun 03, 2008 | Tascam 2488 Portastudio Multitrack...
Panasonic Portable Radio/Cassette Player Logo
216 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
