Question about Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter
How do I use my laptop like turntables, PLEASE HELP
I hve the djx700 but i dont have turntables and i want to use my laptop (macbook) like turntables  i hae traktor and i dont know what i need to connect the mixer to the laptop and how i program it and what cables  please solve it i already have the djx700 and i will be at a party the next weekend :S
  • stbn May 10, 2009
    ok very much thanks but what i need to connect to the laptop please help mee im a noob on this photos please :D
    i mean i connect the master, the both, inputone, what??
  • 371 Answers
A trip to your local Radio Shack should solve your problem with the purchase of a mini phone jack to double RCA type (red and white) leads cable.
Jack into the audio out of your Macbook and into the input of your choice on the mixer with the RCA jacks and you are good to go.
Posted on May 10, 2009
  • Maurice B Thomas
    Maurice B Thomas May 10, 2009
    You might also look into actual software that emulates DJ functions which is found on apple.com on software downloads, many of which are freeware.
  • 63 Answers
Your Better Off Going And Buying A Duel Turntable And Switch Board Setup To Run Through The USB Port Of Your Laptop There Not Overly Expencesive But They Do Work Then You Just Need Vyn's And Your Set :-) I Strongly Recommend Going To A Proper Equipment Shop When Purchaseing DJing Equipment. Incase You Think I Don't Know What Im Talking About I Am A Private Party Computer DJ And Yes I Have The Equipment Mentioned. I Hope This Can Be Of Some Help To You
Im not getting anything from my djx700 master output, getting sound from booth output. what could this be
The first thing I would look at is the kill switches on each side, make sure these are not pressed. Also make sure the master fader is up. I would disconnect anything that may be plugged into the effects loop send and return. Make sure the main outs are plugged in correctly, the main master outs should go to a power amp, this unit appears to be a unpowered unit. Make sure you are using the proper cables to avoid damage, lookup and understand the difference in speaker cords and instrument cords and place them properly. Also make sure the "assign A" and "assign B" are positioned correctly. Hope this helps but, if you give me a little info on how you are using this unit, I could help you further, please.
Mar 27, 2013 | Behringer DJx700 5-Channel Pro DJ Mixer...
Where can i get a replacement assign knob for a djx700
Behringer fired their USA distributed a few weeks ago. You'll have to call Behringer directly and request the part. Or email.goto th website
Nov 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Frustration coming from djx700 mixer left Chanel need help :( on booth and master ??
the faders were actually fails functioning it well, it must be replace a new one!im a audio technician of BEHRINGER!
Aug 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
My behringer djx700 does not work properly 2 use the effects u have 2 plug an rca into the booth output on the back but then nothin else works and i can only here my left turntable in my head phones there...
Semiconductor things involved with sending the booth signals into the mains are:
IC2 which is a 5241 gate controlled by MIC_ON.
IC30 4580 summer for MIC and BOOTH.
IC53 4580 inversion and gain control.
IC39 4580 MAIN output drivers.
May 13, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How can i open the music file for my digital dj pro mixer
I don't know what you are trying to do. But your mixers needs analog inputs such as cd players or turntables.
Feb 12, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Djx700 Headphone (cue) Problem. Please help.
Have a look at page 4 of your manual under the Monitor section, mode switch. Manual is here:http://www.behringer.de/EN/downloads/pdf/DJX700_P0165_M_EN.pdf The mode switch may be faulty or the mix control may be faulty.
Feb 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I need a wiring diagram for the main circuit board in a behringer djx700 mixer
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Aug 26, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I dont know how to connect it to my laptop
I'd recommend either the UCA 202 or the UCA 222. Both are Behringer products and the 222 comes with a software bundle. Check out the energy XTC software, I downloaded it and am having fun with it already.
May 09, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer djx700 pro 5 channel mixer
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Apr 23, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer DJx700 5-Channel Pro DJ Mixer with Digital Effects & Bpm Counter Logo
631 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
