Question about Tools & Hardware - Others
How to loosen screws to remove blades from Ozito OZPL400A planer
The first step in the manual says ''Loosen the hex head screws with the spanner provided.'' There are three screws (actually bolts with hex head nuts) holding each blade in place. I can't get enough leverage with the spanner provided to get the nuts loose. I've tried WD40 but some of the nuts won't budge. Any suggestions? Thanks!
  • O2BAHandyman May 13, 2009
    Thanks for the tips. Couldn't find Liquid Wrench but did find a similar product called "Bolt Off." I tried it, along with a brand new mini-vice grip -- also tried tapping the nuts with a metal punch -- still won't budge. The nuts are partially stripped at this point. Will look into the other things you mentioned (like the air ratchet wrench and propane torch). The planer wasn't too expensive (under $100) so I might just have to buy a new one.
  • 5,660 Answers
WD-40 is nice for some situations, but not this particular one. I suggest you use something like Liquid Wrench. Apply, tap the nuts on each side with a metal punch, and a very small hammer. Not hard! You're just trying to bust any rust loose, and give the liquid wrench a chance to ease down in there.
Just tap!
How are you holding the bolt head on the other side? If these nuts are so corroded that this method won't free them, you make want to see if a 1/4 inch air ratchet wrench is available. The wrench is shaped in a 90 degree angle, so it should fit down in there. Have any mechanic friends? The bolts may break. It may come to this. Be sure the bolt head is held secure, so that no damage will come to the planer. If they, or it, breaks, you can just replace them. Make sure they're Grade 5 or above, bolts and nuts.
I've had to use a small propane torch to heat the nuts. The rust breaks free. I hope it doesn't come to this.
Posted on May 10, 2009
  • joecoolvette
    joecoolvette May 14, 2009
    Is there a way you can get a single blade hacksaw, and cut across the
    nuts? (Mini hacksaw. Looks like this,http://hand-tools.hardwarestore.com/67-4... ) Come down from
    the top on these nuts. Once you slice through one side, they should
    release enough, that those mini vise grips can take them off.
    (If not, cut a chunk out of one side of the nut)
    If you get time, I would appreciate it if you would rate my answer.
Ks656pe how do i change the blade? i don't have any instruction. Please
Quick-Change Blade Mechanism
Higher-end models, such as the Linefinder Orbital Jigsaw, feature a clamping lever to hold the saw blade. To change a blade, switch off the jigsaw, unplug it, and let the used blade cool down. Pull up the saw-blade locking lever and let the used blade fall out with a slight shake. Turn the jigsaw upside down. Hold the fresh blade with its teeth forward; insert the blade shank into the blade holder as deeply as it will go. Release the lever and wiggle the blade to confirm that it's snugly in place. For models with rollers, such as the Accu-Trak, nestle the blade against the rollers.
Clamp or Hex Screws
Loosen the pair of screws -- on the front of the mechanism of models such as the single-speed jigsaw -- a full turn counterclockwise with a flathead screwdriver, but do not remove them. The used blade will fall out. Insert the new blade fully into the clamp. Lightly tighten each screw alternately and then fully. On older models, you may find a single hex screw on the side of the blade. Loosen this enough to remove the blade, and then insert a new blade carefully so the teeth face forward. Retighten the screw.
Oct 03, 2017 | Saws
How to replace blades on a hand held power devil planer (old version)
Try this.
Loosen the fastening bolts Loosen the three bolts that secure the blade.
2. Remove the blade
Now you can use a screwdriver to begin sliding the blade out of its slot. Grab the blade carefully and slide it out the rest of the way.
3. Repeat the process on the reverse side
Now turn the planer's drum around to the other side and repeat the process on the second blade.
4. Install the new blade
Now you can install the new blades. Notice the blades have a notch on them that aligns with the slot on the drum. Align the notch and slide the blade into place.
Loosely tighten the outer two nuts, but don't tighten them completely yet.
5. Align the blade
Make sure the blade is centered so it won't rub against either side of the planer. Once the blade is centered you can fasten the bolts down completely.
6. Repeat the process on the reverse side
Now rotate the drum and install the new blade on the other side.
Jul 22, 2017 | Crafts & Hobbies
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
How to replace belsaw planer 910 blades
You need to tap down the gibs with a brass punch. They are tapered and tapping the down will loosen the knives.
Oct 29, 2009 | Tools & Hardware - Others
I do not have a manual for my mastercraft maximum 13 inch planer and would like to know how to remove the blades for sharpening
If it is anything like my 12 1/2 inch mastercraft planer you will need to remove the dust guide first, and then the drum with the blades will be visible. To remove the blades you need to loosen the bolts with the appropritate sized crecent wrench. Seems to be the only part of my planer that does not require an allen wrench actually.
Oct 20, 2009 | Tools & Hardware - Others
I am trying to change the blade on my Bosch PHO1 planer. I have taken out the two grub screws holding it but it won't release - any ideas?
If the blades are hard to remove, you will have to remove the blade clamp completely in order to clean everything up. Your blades are probably gummed up from use. If you have a small torch available, you may want to try heating it up a little, this will release the blade (if you are using HSS blades). Be carefull not to melt any plastic in the surrounding areas. If you are using the micro carbide blades you should be able to press the blades out from the side using a scrap piece of wood without removing the screws (just loosen). Use mineral spirits or lacquer thinner or alcohol to clean all surfaces so your new blades will seat properly.
Oct 09, 2009 | Bosch 1594K 3 1/4" X 3/32" Planer Kit with...
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Planer does not cut evenly across the table
You have to loosen the screws on the blades and adjust them. It tells you how to proceed in your owner manual
Apr 05, 2009 | Tools & Hardware - Others
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Blade Change for Bosch 1581
the screw is a flat head but you need a long series screwdriver you have to loosen the screw first then turn the blade sideways remove then place new blade in sideways turn to straight then tighten screw again its not too hard at all best of luck glenn.......
Nov 11, 2008 | Saws
Tools & Hardware - Others Logo
516 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
