Question about Cuisinart EM-200 Espresso Machine
New to expresso machine - Cuisinart EM100c
I just bought a Cuisinart EM100C expresso maker yesterday and I'm totally new to this. I tried to rinse the machine as instructed for the first time use. When I turned the machine on, I heard a noise right after I pressed the Start button [2 seconds], then I waited until the light is off, I poured cold water down the reservoir and followed the instructions to turn the knobs... then I hear the same noise for about 5 seconds and still no water coming out. I was worried so I turned the machine off right away. Is it normal to hear the loud brewing noise during the entire process?
  • Anonymous May 24, 2009
    I have the exact same problem, looking online for an answer since customer service is closed.
  • vickersca492
    vickersca492 Feb 24, 2013
    I have the exact same problem. Just bought my cuisinart EM 100 and I get the noise but no water goes from resevoir to cup. I watched video 3 times and rad booklet and still cannot figure out what is wrong. Can anyone help me as customer service is closed.
  • 8,596 Answers
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
Posted on Jun 12, 2009
  • vickersca492
    I did all of the above. Where is the knob to the left on water or steam or is it shut off
55108 Espresso & Coffee Maker: I need a new expresso pot for my Model #55129...
You can order it from the West Bend site:
http://www.focuselectrics.com/finditem.cfm?itemid=4401
May 16, 2010 | West Bend 55108 Espresso/coffee Maker
My brew station is totally dead...no problems before now and is fairly new.
I have the same problem with Cuisinart COD 4000. I called the Service Department and will receive a new coffee maker.
Nov 29, 2009 | Cuisinart Coffeemakers
Cuisinart DGB-700BC grinds but no grounds in the basket.
Hi there, you have some kind of blockage, If the beans are going down, you need to remove the brewer unit and wash it, if the beans arent going down the exit of the grinder is blocked and needs to be removed, cleaned and replaced
Jul 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Recently bought a used Cuisinart DGB500 and do not have a manual. I should be able to figure out the controls but believe there is supposed to be a water filter. No sign of one that I can find. Also, does...
Yes. the paper filter absorbs yhe oils and traps fine sediments. Look up how expresso machines work by typing it in the search bar. It may refresh your nenory. Good Luck
Jul 11, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
I have a Cuisinart DCC-1200 coffee maker. It's worked flawlessly, but we just moved and when we arrived at our new house, we plugged it in and ....NOTHING! It acts like there is no power to the machine....
Most likely totally dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Dec 11, 2008 | Cuisinart DCC-1200 Coffee Maker
Totally dead machine.
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Aug 31, 2008 | Cuisinart DGB-500 Coffee Maker
Grinder does not work
I have the spare part number to the grinder.
0301.R01.00A 230V
0301.R001.00F 100V
Hope this will help you.
Jul 20, 2008 | Saeco Magic De Luxe Espresso Machine
HELP FROM EXPRESSO NEWBE
What kind of machine do you have?
Sep 15, 2007 | Saeco 30511 Espresso Machine
Cuisinart EM-200 Espresso Machine Logo
1,953 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
