Question about Dryers
REPLACED BELT BUT IT IS NOT TIGHT ENOUGH
REPLACING BELT AND HAVING TROUBLE GETTING IT TIGHT
  • tom wright
    tom wright May 11, 2010
    You can use the bag instructions on how it goes around shaft or talk to your local parts department on that.It sounds like you put the belt on wrong good luck:)
  • 1,305 Answers
Go right HERE: http://www.repairclinic.com/0079.asp pick your dryer model... follow their directions for routing... make sure the belt is not in the indentation of the drum... you can do it!
Posted on May 10, 2009
Serpintine belt wont tight ,idler pully is in good shape old belt came off thought it had streached it was almost new replaced it still having same problem.
Are you sure the belt tensioner spring is strong enough to keep the belt tight ?
You should have to move the tensioner to put the belt on, then it should keep the belt tight when you finish.
Apr 19, 2013 | 1996 Ford Taurus
How do you tight the serpentine belt in a matrix. when i am putting in the alternator back in place but am having trouble putting in the belt on it.
It takes a long wrench to turn the bolt for the tension pulley.
You release tension on the belt to remove it, then let go of the pulley when you have the belt back on.
The tensioner is spring loaded and keeps the belt tight.
There is a video on YouTube.
Mar 06, 2013 | Cars & Trucks
The belt on my hotpoint aquarious wma33 keeps coming off
Belt is not adjusted tight enough when being fitted, if no adjustment can be made by moving the motor then the belt may be stretched and will need replacing, the drum bearings may be faulty and causing the pulley to be out of alignment, water may be getting on to belt causing it to slip off.
Dec 29, 2012 | Hotpoint Washing Machines
Trouble with manual shift after replacing drive pulley
If the pulley is a bigger diameter it will make the belt too tight when de clutched, as the gearbox is a simple crash style bo, any movement or drag on the gearbox pulley will stop you engaging gears.
Jul 08, 2012 | Garden
Noisy fan belt
with a noisy belt its caused by a worn belt,belt not tight enough,a pulley in poor condition or grease/oil on the belt.check the condition of the belt,make sure the belt is tight enough.if it has an auto belt tensioner it may not be any good and need replacing.if the noisy belt doesn`t use an auto tensioner then the belt will need tightening.if its grease/oil then the belt will need to be replaced and the pulley`s cleaned off.
Jul 25, 2011 | 1998 Land Rover Discovery
1996 nissan maxima screaches when started after replacing belts.
it sound like a water pump barring water pump problay on its last leg they have a spray for belt in autozone or cks
Jan 17, 2010 | Nissan Maxima Cars & Trucks
Belt needs replacing
Tip the washer back and the belt is underneath, just pull of and replace - simple.
Dec 29, 2009 | Admiral AW22 Top Load Washer
I have a 94 Ford Escort, installing the timing belt. It's extremely tight and am having trouble getting the belt to settle into the teeth of the camshaft sprocket. How do I get this to fit?
did you remove the tensioner? or recoil the tensioner? you could have been given the wrong belt- that has happened to me couple of times.
Aug 25, 2009 | 1994 Ford Escort
Alternator belt installation
You need to pull the tensioner back or you are routing it incorrectly.
May 13, 2009 | 1999 Mercury Mystique
My 2003 mazda protege squeaks when i start it in the morning i had my belts replaced but it still does it when I start it
just replacing the belt wont do the trick belt has to be properly tightened, usualy it is the power steering belt which is hard to reach and tighten so make sure that all hte belts are tight enough
Nov 13, 2008 | Mazda Protege Cars & Trucks
Dryers Logo
Top Dryers Experts
