Question about RCA F32450 32" TV
Will not turn on.
I checked power supply and found voltages to low, caused by shorted horz.
output transistor (TL02).
Replaced TL02 transistor and power supply standby voltages returned to normal. But can not get set to turn on. I can see the green lamp at the on/off button cycle on and off and the horz. circuit follow suit, but will not
maintain on condition
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
  • proceed as given after your power supply is ok (your statement)
  • isolate power supply from h/output stage.
  • check diodes & capacitors connected with flyback transformer.
  • check for print short.
  • ckeck h/output transistor.
  • connect supply to h/output stage.
  • put on the set.
  • hope this will help.
  • good luck
still there is a drop in voltage then your fly back transformer faulty.
Posted on Oct 12, 2007
TV won't turn on. Is there a fuse that needs replacing?
Good day!
When the TV is not turning ON it doesn't mean that there's a busted fuse inside although it have a possibility.There are a lot of causes to be considered.Like shorted transistors,leak capacitors open resistors and shorted diode.
Follow this D.I.Y procedures to find the exact problem of your TV.
  1. Remove the back cover of your TV.
  2. After that,find the power supply board.
  3. If you already found the power supply,plug-in your TV and power it ON.Check the input voltage of it,using multimeter (AC range).If the power supply have no input voltage the problem could be the power cord.Replace it.
  4. If the power supply have the input voltage,try to test the output voltage if have 5vdc for the system and logic supply,12vdc for the sounds and 24vdc for the back-light inverter.Use your multimeter tester (DC range) to test that.
  5. If the power supply have a voltage outputs such as 5vdc,12vdc and 24vdc and the problem is still there.The problem could be the main board.Replace it with the same type and model # because the main board is no very difficult to fix and its very sensitive.
  6. If the power supply have no output voltage or the voltage is too low,just ignore the step # 5 because the problem is not on the main board,its on the power supply board.
Check the following to fix the power supply board:
  • Fuse: Check the fuse if it is busted or blown.
  • Power transistor (regulator): Check the regulator if it is shorted or leak.
  • Resistor: Check the resistors specially the one that have a low resistance that near the power regulator.
  • Capacitor: Also check the capacitors if it is leak or bulging top.
NOTE: If you found any defective parts or components that mention above replace it with the same value,type and ratings.
Thank you and good luck.Please don't forget to vote and rate my answer.
May 08, 2011 | Televison & Video
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Jan 01, 2009 | Rockford Fosgate Punch 401S Car Audio...
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
I have an audiobahn A8000t amp with the protection light on
Note:
Dec 30, 2008 | AudioBahn A8000T Car Audio Amplifier
I have a fosgate 301x with power to the amp but none coming out
Note:
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Dec 30, 2008 | Rockford Fosgate Punch 301X Car Audio...
Well my amp comes on but it doesnt give out like bass power or its jus not working like it use to the light comes on orange or red
Note:
Dec 30, 2008 | Visonik V4208 Car Audio Amplifier
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
RCA..PTV..P60924..CTC195M..NO START UP.
High failure parts = Flyback.....# 239111 and HO transistor =
237470 ....DO NOT USE cheap generic.................T.
replace both at same time......................T.
Dec 21, 2007 | Televison & Video
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
RCA F32450 32" TV Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
