Question about Alpine CDA-7840
Alpine cda7840 not working
My hu will act like the it is working according to faceplate but no music every thing is hooked up correctly. nothing comes out with radio or cd.
Sorry in wrong area. While I am here did u find a solution for this problem? I am having same problem. Please tell me how I can fix this problem. Thanks Bunches
Posted on Sep 04, 2010
Alpine 7889 interface not working correctly
hook all of the wires up, then hook the red blue and yellow wires all together.
Jan 28, 2014 | Alpine Kca-420i Kca-121b Ai-net3.5mm Mp3...
I have a peavey triflex first addition hooked to peavey pv14 mixer everything works great till I turn the volume down then the subwoofer stops working the power is on but nothing at all coming from it it...
Your sub may have one of those annoying circuits that turns it on in accordance with overall signal level. Supposed to act as a subsonic filter.
Aug 24, 2017 | Music
My cda-9813 wont power on,how to take of faceplate?
Here is a link to the owner's manual for your stereo, it shows how to remove the faceplate:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9815.PDF
May 14, 2010 | Alpine CDA-9813 CD Player
My Alpine CDE 7872 faceplate goes blank intermittently, the unit still functions, just can't see what station you are on, what track, volume, etc...
is the faceplate detachable? if so remove it and clean the metal contacts on both the din unit itself and the faceplate with rubbing alcohol on a cotton swab or Q tip.
if it is not a detachable face, then i would say an internal solder joint is starting to come loose, that is an older alpine model number after all.
Dec 16, 2009 | Alpine CDE-7872 CD Player
My Alpine CDA-9835 has a short in face plate, plays music but unable to change tracks, display goes black, and usually have to remove faceplate and re seat over and over till it comes back on usually...
most of the time you have to send the faceplate into the manufacters repair dept or a factory authorized repair center will most likely need the entire radio/ unit to repair the faceplate problems
Good Luck!!!
Larry Dillon
Aug 26, 2009 | Alpine CDA-9835 CD Player
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Aug 20, 2008 | Alpine CDA-9856 CD Player
Still no sub woofer output
SET THE CROSSOVER TO "L.P.F."POSITION AND SELECT THE LOWEST FREQUENCY AS THE CROSSOVER POINT.
[AN AMPLIFIER IS SUPPOSED TO "AMPLIFY"(TO INCREASE)ANY OUTPUT.]
TRY CHANGING THE POLARITY OF WIRES FROM AMPLIFIER TO SPEAKERS /SUBWOOFER.{it leads to cancellation of bass output.}
if u still have doubt contact me again.
May 26, 2008 | Alpine CDE-7856 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Alpine CDE 9881
You must have a faceplate from that exact model, no others will work. You can try to contact Alpine for a replacement. If it is any consolation, someone has a useless faceplate, because it won't work with anything else, either. Try running an ad in your local lost & found column, you just might get lucky, especially if you offer a reward.
Jul 28, 2007 | Alpine CDE-9881 CD Player
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
