Question about Kirby Ultimate G Bagged Upright Vacuum
Shampooer i can't get the shampoo to suck through the hose. I get nothing out of it. What do i do?
  • 357 Answers
Re: shampooer
View my shampooer use guide onling by clicking this special attantion to the part about the little suds screen that goes on the small hole in the tank where the hose connects.
Posted on Oct 25, 2007
0 characters
3 Points
Can't figure out how to attach hose from plastic shampoo container to vacuum
The below link is to a Kirby site that provides a video for attaching the shampooer. Very informative.
Jan 22, 2011 | Kirby Shampooer Shampoo Hose G3 Ultimate...
My shampooer only sprays a single stream of shampoo and water whenever I use it on the carpet... That and I can't get it to lay a nice even layer of shampoo to soak in and then pick it always does...
You are probably missing the foam screen on the tank outlet. There should be a plastic disk with a fine screen in it on the tank outlet. If the screen is missing, foam will not be produced; and just soap water will be sprayed out. Sometimes the screen assembly can be found in the end of the shampooer hose.
Nov 01, 2010 | Kirby Shampooer Shampoo Hose G3 Ultimate...
Dirt Devil Featherlite carpet shampooer won't release solution
Had the same problem only after 2 uses, called the 1 800# said that soap may have "gummed" up the line did everything they said but didn't work. Would cost more in service repair if I could find a authorized dealer to fix than I paid for the machine. Would not recommend this machine to anyone.
Jun 10, 2009 | Dirt Devil CE6100 Featherlite Upright...
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further...
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
G5 not dispensing anytyhing
You are missing the little screen that goes on the small hole in the tank where the shampooer hose attaches to the tank. Read this shampooing instruction guide for more info....
Jun 07, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Shampooing with the kirby
In the cap where you fill the shampoo, make sure the filter and components are clean
Apr 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly. one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
Dec 07, 2007 | Vacuums
Kirby Vacuum Shampoo Attachment
If your trying to shampoo your carpets but the water flow is to weak and it trickles through the spout to the carpet leaving small puddles
This problem often occurs when the foam filter is not replaced after rinsing or ends up in the shampoo hose at an angle preventing foaming. If you take the small shampoo hose of the shampoo tank the filter should be on the tank, if not, it may have come off and be in the hose. If it’s not there locate it, likely in the area where you last cleaned the shampooer or in the box, and put it back on the tank. While this should be cleaned after each use, care should be taken to replace it and not lose it.
The problem may also occur if you don’t actually add the Kirby Dry Foam Shampoo to the water or if you use some thin else.
Take care to also clean and replace the air filter after rinsing. It is located under the shampoo tank where the tank fits onto the vacuum.
Sep 07, 2007 | Vacuums
Carpet shampooer
hi, I used to sell these, and can tell you that they are not designed to suck up the water. They are made to put a limited amount down and then the brushroll scrubs it. Then it drys and ideally you would vacuum up the dried residue that is left. I own one myself, and admittedly the shampooer is not as good as the ones that steam clean and suck it up, but it does ok. The longer you sit in one area, the more water is going to go down, so keep it moving. And remember that it is going mostly at the middle of the unit, so it's good to overlap a bit. If you have troubled stains, I can suggest spraying some type of cleaner on it and going over it with the brushroll--like windex. My buddy also used to sell them, and that worked for him.
Sep 02, 2007 | Kirby Heritage II Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
128 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
