Question about GPS
How to change screen language to English?
My garmin unit, the screen in not in english. how to reset to english?
  • 1 more comment
  • tiny tim Oct 12, 2007
    help
  • Anonymous Dec 26, 2007
    my tom tom is not in english what do i do to reset to english
  • Adrienne Marks Apr 07, 2013
    I have a game on GamesDay "Doors & Rooms" in Japanese would like to change it to English
I accidently hit the wrong language. How do I change this to english?
Posted on Dec 24, 2009
To change g.p.s from japanese to english is this possible this comes fitted in the dash of a toyota prius import
Posted on Oct 21, 2009
How do I factory reset Garmin nuvi
I found it online, please carefully follow the steps :
Note: A master reset will erase all waypoints or Favorites and will restore your unit to the default factory settings. If you would like to back up your Favorites to your computer, you can find instructions to do so here.
• Start with the unit OFF and unplugged from power
• Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
• Continue touching and holding the lower right hand corner of the screen then power the unit ON
• Release the power button when the device powers ON
• You will see a new message: Do you really want to erase all user data?
Remove your finger from the touchscreen when this message displays
• Touch Yes (If text language is not in English, this is the button on the right )
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Aug 01, 2014 | Garmin Nuvi 465T Car GPS Receiver
Froze on garmin screen won't give directions
Could be a battery problem not having enough charge to get past the Garmin screen you might need to replace the battery or it might need to be reset.
Not knowing which model of Garmin it is makes it hard to provide a correct solution. ?
If your Garmin Nuvi 1300 is freezing up or not working correctly, a soft reset can be performed. A soft reset unfreezes the unit and brings you back to the main menu. If a soft reset does not solve the problem, or if you are selling your unit and wish to erase all of your saved information, a hard reset can be done. A hard reset restores the original factory settings to the unit. Once the information is deleted, it can not be restored. Turn on the Garmin Nuvi 1300. Press and hold down the "Power" button. Release the button when the main menu is displayed. The unit is now ready to be used. b> Hard Reset b> Turn the Garmin Nuvi 1300 off. Press your finger against the bottom-right corner of the Garmin display screen. Leave your finger in place as you power the unit on. Release your finger when the display screen asks, "Do you want to erase all user data?" Use your finger to tap "Yes." The unit will begin to reboot. Do not use the unit until the main menu is displayed. The reset process should take about 45 seconds. Hope this helps.
http://www.youtube.com/watch?v=xjUSGY7KVAk How to Replace Your Garmin Nuvi 255 Battery
Jan 04, 2013 | GPS
My garmin is in japanese i need english
Try this:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Feb 28, 2011 | Garmin nuvi 205 GPS Receiver
My garmin nuvi 250 is now only in spanish - I want english
Hello, you should be able to achieve this by resetting the GPS since its default is English.
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck
Jul 19, 2010 | Garmin nuvi 250W GPS Receiver
I need to change the language on my my garmin nuvi 1300 gps from chinse to english
Garmin uses picture icons for most of the settings. When you forst turn the unit on you will see a magnafine glass map speaker and wrench. the wrench is tools press that. the next set of icons you will see another wrench that is settings press that. The next set of icons there will be a pair of lips that is language press that. The next screen is harder this is the language screen the upper left blue button is voice, the spoken directions, the upper right is text, the one you need to change, the lower left is keyboard. Select the text button, the languages are alphabetical so scroll up to american english, the screen will refresh then press ok.
The other solution is to do a hard reset. It sounds like you got this unit used or a floor model that someone changed the language on. It might be in your best intrest to reset to clear all saved info that others have input.
Jun 11, 2010 | Garmin nuvi 255W GPS Receiver
How do I change the country on my Garmin nuvi 255W?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Stuff happens. Try this:
This may be a result of a previous software version on a device or possibly some one changing the settings. If a device does power on with a foreign language that you can not understand it can be corrected by going through the settings to change the text language.
To change the text language:
  1. Touch Wrench icon on the screen with the Magnifying Glass and Map icon
  2. Touch the Gears icon
  3. Touch the down arrow
  4. Touch the second option from the top1
  5. Touch the middle blue box on right
  6. Touch the up arrow until American English appears2
  7. Touch American English
  8. Touch OK
  9. Touch Back
The device should be in selected text language.
Note 1 - In some cases, if there are Custom POIs loaded to the device then it may be the first option at the top.
Note 2 - If American English is not the language needed, please selected the desired language
Jan 29, 2010 | Garmin nuvi 255W GPS Receiver
I cannot get English on the Garmin. All of the
Slide the power switch whilst pressing the bottom right-hand corner of the screen this will reset the unit if its a UK or USA shipped it will revert to English or American English
Jan 05, 2010 | Garmin nuvi 250W GPS Receiver
The words on the screen are in German. How do we change it to English?
You didn't specify your unit, but here are the instructions for Garmin Nuve 200 series navigators.
Go to:
Tools > Settings > Language > Text > American English
You may need to reset the voice languagealso if it is speaking foreign tounge.Hope this helps.
Dec 19, 2009 | Tomtom ONE 3rd Edition GPS
I cannot get my Garmin 650 off a foreign language to English. Help
there is a master reset switch on the back of the unit take a small pin or something and reset the unit to the day you bought it
Dec 09, 2008 | Garmin GPS
GPS Logo
2,843 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
