Question about Dell Optiplex GX270S PC Desktop
Stops at windows start - Dell Optiplex GX270S PC Desktop
  • 31 Answers
Try on recovery console. try command fixboot /r, it will complete soon. if u have more error try fixboot /p it take some time, and try to restart the comp.if nothing works.
i belive it is due to file corruption on the os,its better to install os in another drive are same drive with another folder name .and copy all the file which u dont want to loose .and reinstall os completely.
i hope this will help u to fix
Posted on May 10, 2009
WINDOWS 7 how to block and stop unwanted programs
This means you are suppose to stop all the unwanted programs in the windows 7 to improve the performance of the operating systems.
There are several ways to block & stop unwanted programs, in the operating system itself there is firewall which helps you to stop the unwanted programs using "Allow/Block" rules.
You can find lot of freeware programs to stop and disallow when windows starts.
Few of them are comes with Antivirus programs with firewall protection,
Ccleaner - To remove unwanted information and unwanted startup services.
To stop programs temporarily you can use Windows Task Manager. This can be open by pressing CTRL+SHIFT+ESC you will see all the present running process, start-up services, system services.
Or
You can click on START+R to open RUN command prompt
Then type SERVICES.MSC then you will get all the system services which are running continuously if you are familiar with your programs you decide what programs to stop and disable from start-up.
Caution: Use this program (services.msc) when you are familiar stopping system services may stop functioning of some features or OS may crash.
Hope this will be helpful
Regards
Nandu
Sep 30, 2013 | Microsoft Windows 98 for PC
Tip
How to stop the Annoying Windows Automatic Updates Restart Dialog box
YOU CAN TRY THE FOLLOWING STEPS TO DISABLE AUTOMATIC UPDATE SERVICE.
  • GO TO START-RUN
  • THEN TYPE CMD CLICK OK
  • IN THE COMMAND LINE TYPE THE FOLLOWING COMMAND AND HIT ENTER
  • "NET STOP WUAUSERV" COMMAND (LESS QUOTES) TO STOP IT
  • AND "NET START WUAUSERV" TO START IT.
  • WINDOWS XP USERS HAVE TURNED ON AUTOMATIC WINDOWS UPDATE WILL HAVE ABSOLUTELY NO PROBLEM
  • RECOGNIZING THE "RESTART NOW, RESTART LATER"
  • THE EASIEST WAY TO STOP THIS ANNOYING WINDOW IS TO START WINDOWS COMMAND PROMPT (START -> RUN -> CMD)
  • AND TYPE THE FOLLOWING COMMAND:
  • SC STOP WUAUSERV
  • AND THEN HIT ENTER.
  • THE RESTART WINDOW WILL DISAPPEAR IMMEDIATELY INCLUDING THE ICON IN THE SYSTEM TRAY.
on Feb 19, 2011 | Computers & Internet
Stop mouse blinking when windows start it stop when online
Remove Download Accelerator Plus. If the problem goes away then don't use the accelerator again. they aren't really necessary on windows 7.
Jul 20, 2012 | Computers & Internet
HP Laserjet 1320. Will not stop printing and not showing up in the Que. I have unplugged overnight, I have cancelled all jobs in the Que and will not stop printing. How do I cancel the job
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click START
Click RUN
Type CMD ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 07, 2010 | HP LaserJet 1320 Printer
How do I cancel an order to make it stop printing and clear it out of the system
Click on Run
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
Type
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jun 23, 2010 | Zebra 105SL Thermal Label Printer
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
My computer will not install updates. it says it is installing them after it shuts down but they never install.
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Regards,
Om
Oct 11, 2009 | Microsoft Windows XP Professional
UNABLE TO INSTALL SP2 ON XP OP.SYSTEM
net stop wuauserv
net stop bits
net stop cryptsvc
net start wuauserv
net start bits
net start cryptsvc
Regards,
Om
Oct 01, 2009 | Microsoft Windows Xp Home Edition Sp2...
Windows script host
My Documents Folder - Opens Upon Boot
To Stop Windows Explorer from opening My Documents: Check your settings here: Start/Run/Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
In the right pane under Userinit - Change the key that reads:
C:\Windows\System32\Userinit.exe,C:\Windows\System32\Userinit.exe
To:
And also here: Start/Run/Regedit
Start/Run/Regedit
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows. In the right pane, check your settings under Load.
try this rate the solution
Jul 06, 2009 | Computers & Internet
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
Dell Optiplex GX270S PC Desktop Logo
Alun Cox
