Question about Sansui HDLCD3210 32 in. LCD TV
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
The volume on my HD LCD 3210 just started turning itself down to 0. The remote volume won't work, but the rest of the remote controls the TV just fine.
  • exchfamily May 10, 2009
    I checked the remote, but the buttons were OK. One thing I did try was unplugging the TV from the multi-plug power surge protector and plugged it into a different outlet. So far, the sound has stayed on.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
Posted on May 10, 2009
The volume lowers itself all the way down to 0 and the zero continues to flash like it is still attempting to lower
You can't reset it you have a sound problem circuit that needs to be fixed by a qualified tach.
Nov 01, 2012 | ViewSonic N2750w 27 in. HD-Ready LCD...
RCA LCD TV locked up.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 12, 2012 | RCA RCR312W Remote Control
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Jun 28, 2012 | Televison & Video
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
Jun 09, 2011 | Televison & Video
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
May 06, 2011 | RCA Televison & Video
I was trying to look for the input, and accidently locked the screen
You will need to have the remote:
Press the VOL+ on the remote control and the CH+ button on the front of the TV.
The TV will prompt you to enter a new password.
May 03, 2011 | RCA TruFlat 27F520T 27" TV
AT NIGHT, TV SWITCHES ON AUTOMATICALLY AND CHANGES FROM SIDE AV TO OTHER OPTIONS, I.E. PC / HD 1 ETC. LAST NIGHT TV SWITCHES ON, CHANGED TO HD1 AND TURN VOLUME AUTOMATICALLY TO 0. CAN'T GET VOLUME UP. WHEN...
what you describe is almost impossible ..the only explaining is someone with a compatible remote control messing around with you ..so ...pay attention ..and after that if you are completely sure that this is out of case...Leave a comment and I will search for another possible cause ..
Mar 17, 2011 | Philips 42PFL5332D 42 in. LCD Television
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
TV doesn't turn on
I have a Mintek DTV265 which is almost the same TV the red light don't blink it stays on as long as the Power button is on. Try turning on the TV by pressing any of the buttons on the side of the TV Channel up or down, Volume up or down , or source. If it comes on then your TV is alright. I had one of them jumbo universal remote controls and it actually had a code that worked on my TV.
Mar 02, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
Volume control not working
Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
Jul 05, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Sansui HDLCD3210 32 in. LCD TV Logo
560 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
