Question about Green Air Hardware & Accessories
Green air digital timer Model CST4, unable to use it, need manual
How do I get an operating manual for a green thumb model 27157?
Orbitonline.com posts manuals under support
Then click sprinkler systems
My experience is that all manuals are not available because there are so many knock-off products and often the company sells a second line of cheap timers that are not made to last and are not supported on company website.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Gene
Water Heater Timers Save Money
Mar 05, 2015 | Orbit Hardware & Accessories
How do we turn off timer?
Will need a model number for the unit in order to assist. Once you've found the model, try googling for "<modelnumber> manual".
Aug 30, 2014 | Heating & Cooling
Programmable Digital Timer Model TE106
Copy following link for possible TE106 timer manual:
http://waterheatertimer.org/pdf/Possible-manual-for-TE-106-timer.pdf
Add comment after trying instructions so we can get exact steps correct if necessary
Gene
Aug 11, 2013 | Hardware & Accessories
Cant set auto on
1) Timer model and brand are unknown.
Copy following link for ST01 timer:
http://waterheatertimer.org/ST01C-program.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) Add a comment and describe timer in detail, and add if this is new installation or older timer that stopped working.
Dec 26, 2012 | Intermatic Inc. ST01C Digital In-Wall...
I lost my manual and am unable to set the timer.
You posted under Woods 59403.
If this is not your timer, add a comment.
Woods 59403 manual
http://waterheatertimer.org/pdf/Woods-59403.pdf
To see all Woods timers to identify your timer:
Dec 05, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
Nov 13, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Need user manual for hitachi logicool window ac
check out this link for the timer:
http://www.logicool-ac.com/pdf/015%20-%207%20Day%20Timer%20Operation.pdf
check out this link for the manual
http://www.logicool-ac.com/tech_downloads.html
Jun 09, 2009 | Hitachi RAS-09UH Air Conditioner
Hardware & Accessories Logo
66 people viewed this question
Top Green Air Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Green Air Hardware and Accessory Expert? Answer questions, earn points and help others
