Question about Craftsman 10" Table Saw
Craftsman 10" tablesaw - Will not start. Have checked everything. Any clue why?
  • smwdsmn May 24, 2009
    I have the same problem. Less than a year old had a brief period when turn switch on there were times had to turn off & on again to get going now does not start at all. Suspect switch or reset switch.
    Problem is taking to Sears tool for repair costs more than tool would be new to replace. went thru similar issue with jointer/planer.
    Steve from Maine
Hello, It could be the reset switch if it came with one. take the cover off where the wire from the motor runs to the switch and see if everything connected if not it could be the motor itself. hope this helps
steve
Posted on May 10, 2009
Manual for craftsman 10 inch table saw model 818320
I think it is great for you to be needing the manual however most of their saws start with something like 315.1710 look for a number with a decimal then look for the manual. seems to me that the model number you have here is the motor model number. Hope this helps.
Apr 14, 2017 | Craftsman Saws
Do you know the specs. on motor of craftsman 10"tablesaw model 315228410
Is there a nameplate on the old motor? If so, it should state the HP, speed and direction of the original motor. If not, a 1/2 HP to 1 HP 1750 RPM motor with the same size shaft that will turn the blade the same as the original should work fine. From the online manual, it appears to have an internal start switch, so the wiring should be standard.
Jun 22, 2014 | Craftsman 10" Table Saw
Need specifications for craftsman table saw model 113.298240
Here is a website where you can download a pdf document of the owner's manual: http://vintagemachinery.org/pubs/detail.aspx?id=2883 Click at the bottom of the pic of tablesaw.
Hope this helps. If it did, please place a vote for me. Thanks
Handie Andie
Mar 28, 2011 | Craftsman 10" Table Saw
I own a 10" craftsman tablesaw (model #
Wait for the motor to cool then try again..... you may use compress air to blow across the motor to speed the process.
Jan 19, 2011 | Craftsman 10" Table Saw
My caraftsman tablesaw was exposed to moisture. The last time I used it, it seized up. Got any ideas about what I should do now?
about the only thing you can do is spray everything with WD-40. and turn or move things by hand. i am not sure what is seized up but if it is the motor then spray the insides with WD and turn it then do it all again until it frees up. if everything feels loose then lightly blow of the excess WD with air and give it a try.
Jan 17, 2011 | Craftsman 10" Table Saw
"..... 52" unifence When turned on, the tablesaw
Hi, have you considered that the brushes on the motor could be needing replacement? Hope this helps.
Nov 15, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
673 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
