Mitsubishi 3.5 split systme fault
I have a mitsubishi 3.5 split system. it keeps cutting out- green light flashes. on heat and cooling. tried pressing reset button....help...cant find instruction manual
  • yvsie_willie May 10, 2009
    thanks for that- hubby went outside and when i turned the system on the fan didnt come on in the unit...hmmph..sounds expensive!..oh joy
  • Anonymous Mar 30, 2014
    when I turn it on the green light keeps flashing
  • 158 Answers
Green light flashing means there was a fault that occurred now it could be power failure which you can try to reset by turning off and on circuit breaker it might reset itself if not there is much bigger problem which need technician
Posted on May 10, 2009
Light 2 and 3 flash in the condenser outside in my mini split system dual zone AC/Heat Pump. My second floor AC unit does not work. Green light comes on, vent opens, green light flashes.
Flashing lights normally are an error code.. this could be anything really. You have to find out what that code is telling you (manufacturer specific). You most likely won't be able to fix this yourself if you can even find what that code means.. your best bet. Get the installer back. Unless you did it yourself. Then your gonna pay a lot for service unless you find someone willing to look at it (not many people will look at systems they didn't put in.)
Otherwise you have a ugly box on your wall that wi?l only flash some lights at you..
Jul 19, 2017 | Heating & Cooling
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
Hi, have a split system 10 years old, unit on wall has one green light flashing 5 times and repeats. Patrick
E5 Communication error between outdoor and indoor
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Helpful?
Jan 01, 2011 | Mitsubishi Heating & Cooling
We have a split system model SCM45ZA 4.5 kw and it is shutting down intermitently, green and orange lights both flashing wont restart unless main power is turned off. It has been inspected, gas checked and...
there is a high limit switch in your air handler it may be tripping because limit is not staying cool enough, check your filter and make sure you have normal air flow and enough retun air, 144 sq inches per ton
Sep 29, 2009 | Mitsubishi Heating & Cooling
Power light is flashing and it isnt working
A multi split system is it? One of the reasons why the light flashes is because one indoor unit is on cool and the other is on heat. Changing the one on cool (or on heat) will fix this. Both indoor units need to operate on the same mode.
Mat
Jul 20, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Heating & Cooling Logo
378 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
