Question about Remington Factory Reconditioned 17-Inch 3.0 Amp AXCESS Electric Hedge Trimm
Remington Axcess hedge trimmer wont run at all.
Remington Axcess hedge trimmer. Out of the box brand new, it ran for 20 minutes and stop/started a few times then died. It completely stopped running,
I received this as a B-day gift in the fall. Trimmers stayed in the box until today.
Thank You
  • 3,740 Answers
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
Posted on May 03, 2010
  • 1 more comment
  • killerbug May 17, 2011
    Is this guy for real???? Checking the fuel lines and inside the gas tank...on an ELECTRIC trimmer???????? Kelly, don't give up your day job. I don't know how you got to guru but I didn't vote for you!!!!!!!!!1
  • Kelly
    Kelly May 17, 2011
    Since you did not provide a model number I had to guess electric or gas.... I replied with a gas response. The no model number problem on the site happens every day on the site. Tech do not work off of a nomenclature and meiter are the tech manuals. Theya re all by model number.
    As for a new hedge trimmer right out of the box that has problems suspect the brushes. If the armature was not polished properly before assembly and has a sharp edge the commutator will grind the brushes down like sand paper in a really quick manner. Your 20 minutes or run time is about right. A broken brush spring can also cause it to not work well or just plain fail.
    My apology to you for using my 45 years of experience incorrectly and not guessing your model correctly. I note above that this is a re-conditioned unit at least under this heading:
    Problem with the Remington "Factory Reconditioned" 17-Inch 3.0 Amp AXCESS Electric Hedge Trimm
    After looking at the heading and seeing 3.0 Amp... yes... I was dead wrong but I still need a model number.
    My best guess at a model number is: RM3017HP and 41AF305G983 http://manuals.mtdproducts.com/mtd/Safet...
    ^-These are the only parts out there for this model.
    Even using the MTD site that is main support site for Remington parts only shows this:
    http://www.mtdparts.com/webapp/wcs/store...
    You best bet at finding brushes for this 3.2 motor is via a service center. I know of no other source for this particular model. I spent 20 minutes looking for a model number and over an hour for free trying to find a parts source.
    The repair you going to need will be in area of the brushes (brush wires, brush, spring, brush clip), and a polishing of the armature commutator with 220 grit or higher sand paper.
    This is the person that tried to help you: http://blog.fixya.com/index.php/2010/05/...
    Thanks for giving me the nudge to pay attention.
    Kelly
  • Kelly
    Kelly May 17, 2011
    Someday I will spell check before posting too... typos...
    Kelly
Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
Aug 13, 2014 | Sears Craftsman Convertible 25cc 2 Cycle...
Echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Nov 26, 2013 | ECHO, Inc. 20 In. Double Sided Hedge...
Where to get the parts? Cam & blades
http://www.remingtonchainsaw.com/parts.html
To the best of my knowledge, all parts have to be obtained online. Remington (DESA) went out of business in 2008/2009. They are now owned by MTD. It is still unknown if MTD will continue to offer parts for the older units.
Jan 04, 2011 | Remington Factory Reconditioned 17-Inch...
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
We have a hedge in our yard. When I saw your
I'm sorry to tell you this but RemingtonPower is no longer in business.
Providing a link to a company that has no replacement parts and will probably not resume production in this lifetime isn't fair to you the customer. Sorry
Lou
Nov 03, 2009 | Remington At3017b Hedge Wizard
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Same problem. New last fall, quit after 30 min.
The brushes for the trimmer is no longer available, so unless you can find someone who has old stock of the part, your going to have to replace this one.
Jun 15, 2009 | Remington Factory Reconditioned 17-Inch...
Will not start
did you try the air filter. could be not getting air. And are you sure it is firing. if so try a spray of ether. You can but at auto parts store. but be careful with it. don't use much. If it is firing it will go.
Jun 06, 2009 | Craftsman 22" Gas Hedge Trimmer
Remington Factory Reconditioned  17-Inch 3.0 Amp AXCESS Electric Hedge Trimm Logo
563 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
