Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Computer will not recognize ip address Linksys adapter
Windows XP desktop-Cpmpaq Presario-Older but fast and good until now adapter works fine on 2 other computers have tried to uninstall and reinstall from cd ready to throw computer out the window! Will not recognize ip address on linksys usb adapter. Will work on 2 other computers.
  • 19,396 Answers
Try downloading the latest drivers from the link below:
Linksys by Cisco - WUSB54GSC Support
Posted on May 16, 2009
My WRT54G wireless router does not connect to our laptops. The (4) wired ports work fine. What am I doing wrong?
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
Does not recognize ip address on network adapter card and can't get online. It use to work fine then all of sudden its like poof its a problem
is it connected to the wireless network ? If not then connect to the wireless network again. What is the Operating system on the computer ?
If it is XP then switchover to Windows utility to connect to the network.
Click Here for more info
Nov 28, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
We have a Linksys G Router. It works fine on my son's (Host) computer. My work laptop will recognize the wireless network but will not connect. My home desktop will not recognize the network. What are we...
There are wireless networking capabilities of the gateway that will prevent or allow specific MAC Addresses from connecting to the network. Go into the wireless settings and adjust the settings to accept the MAC address from your work computer. To find the MAC address from your computers network adapter go into a command prompt by typing cmd in the run box and typing "IPconfig /all" in the window. The MAC address is there it may be called Physical Address. It is always a 16 set of number and letter combinations divided by ":" between every 2 sets of number / letters. On your home desktop this same window will help you diagnose the problem. Your son's computer will help you with this, do this on his as well and compare the IP address with your home computer the address could be something like "192.168.1.?" the last number is going to be unique if the first three numbers match. If the IP address on your home computer doesn't match the first three octets "192.168.1" it will not get out through the gateway. If they don't match you can force it to be on the same network by setting up a static IP address by opening up the Control Panel / Networking icon and finding the icon for the network adapter that you are using and opening it up and clicking on "Properties" and clicking on IPv4 and clicking properties and clicking on Specify IP address and typing the first three octets of your son's computer and adding a fourth number that isn't "0" or "255". You can use any number between those two numbers except those numbers, and isn't the same as your son's IP Address or the Default Gateway which is the Linksys. The "Subnet Mask" will auto install but will be "255.255.255.0". The default gateway and DNS server will be the IP address of the Linksys which most likely will be "192.168.1.1". Click "Ok" on all the open dialog boxes and the computer should be able to get on the internet.
Sep 17, 2009 | Linksys Wireless-G Broadband Router
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
IP ADDRESS
I need to know a little bit of information. Could you please go to start>run>cmd. In the command prompt type "ipconfig /all" without the quotation marks. Please let me know the information displayed.
May 09, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
WRT54G linksys router
The first thing I would do is check to make sure the desktop with XP has the network card set to "obtain an IP address automatically"
if it is set to obtain an ip address automatically, I need to know the following:
What is the IP addresss of the router?
What is the IP address of the Vista computer?
What is the IP address of the xp computer?
You can find the ip address by going to start, then run, then type cmd and hit enter. at a command prompt type: ipconfig and hit enter.
Feb 21, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Linksys Wirless Adapter not recognizing IP address
Make sure that your security password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
Jan 11, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
309 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
