Question about DeLonghi DH100P Dehumidifier
Unit is running but the humidty level doesnt drop and there is no water coming out of the unit
  • 148 Answers
Sounds like you may have a refrigerant problem needs to be charged
Posted on May 10, 2009
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt impact...is this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
Jun 25, 2015 | Dehumidifiers
Have had the Kenmore 54351 Dehumidifier for 2 years. I started it up recently. Had it run for days. Not a drop of water. How do I fix it?
It may simply be a case of 4 things: Any of which can cause the problem.
1. The air intake filter is dirty or clogged.
2. The humidity extraction level is set to HIGH. Lower it to 32%.
3. Obstructed air flow around the unit. You must maintain a minimum of 12" clear air space around the entire unit, while in operation.
4. The ambient air temperature at floor level is between 40 & 60 degrees F. This is true in basement applications and the unit will not function properly. Unless it's a Low Temperature unit. Placing it up off the floor on a sturdy table or counter top that can adequately hold the weight of the unit, plus a full bucket of water, usually solves that problem.
Worse case scenario, the compressor needs to be recharged with refrigerant gas. But, that doesn't happen that often.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Kenmore 54351 Dehumidifier
My dehumidifier runs and the refrigerator or cooling unit turns on, but no water comes into the bucket? Last year it was running fine? fans run and the humidity level is high in the basement
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 09, 2011 | LG LHD45EL Dehumidifier
Didn't LG produce some bad Humidifiers several years ago and have a recall on not working units? I recall reading this in Consumers Reports. I bought one back then and it has not produced a drop of...
If has not produced a drop of water for several years, then it's not working properly. But, this may be a case of setting the humidity level to high. In other words, if you set it at 70% or Maximum, that's the humidity level that it will maintain, not remove. To remove humidity, the level must be set low (35% or Minimum).
To test the unit, based on what I just said, place it in the bathroom, set the level as low as possible and turn the shower on medium hot. Do Not turn the bathroom exhaust fan ON. As you leave, close the bathroom door. Return in 15 minutes, turn the shower OFF and check the bucket water collected. If there's any water in it, it's working fine. It was probably a case of the humidity level being set to high.
Hope this helped you. Please let me know. Thanks.
May 16, 2011 | LG DH305 Dehumidifier
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
The humidifier runs but is not collecting water... so humidity level never drops.
My brand new frigidaire 50 liter dehumidifier has been on for two days and has not collected water from my damp basement. It is on the factory settings: high fan and "CO" (continuous).
Aug 10, 2009 | Maytag M7DH65B2A Dehumidifier
I NEED TO KNOW WHAT PERCENTAGE MEANS ON A DE-HUMIDIFIER
In plain English, the Percentage setting on your de-humidifier is the percentage of moisture that you want to maintain in the air. Relative humidity level range from about 10% (VERY dry air) to almost 100% (VERY damp air). When relative humidity is 100%, water vapor in the air will turn into rain, condensation, dew, snow or frost. 50% humidity is usually a comfortable level, but that will also depend on air temperature. The more moisture there is in the air, the warmer it feels and conversely. Warm air will hold more moisture than cooler air.
Your body is cooled when moisture on your skin evaporates into the air, carrying body heat with it. As the humidity in the air rises, less of your body moisture is able to evaporate and thus your body feels wamer. Lower humidty allows moisture from your body to evaporate more quickly and you feel cooler, both at the exact same temperature.
Jun 28, 2009 | Kenmore 54701 Dehumidifier
Humidty reading remains at 84%
Dehumidifiers are generally a very simple appliance, however a humidistat is one of those items a person tends to rely on to provide feedback. You may want to remove the grille area where the humidistat is mounted and inspect for foreign material in the way of the sensor. If nothing foreign is detected then you should replace the humidistat.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 29, 2008 | Danby DDR586R Dehumidifier - 58 Pints...
No water filling in tank (whirlpool Gold AD70USS 70 Pint Per Day)
the unit has a sealed system leak that need to be repaired by sears 1-800-905-9505 for service
Apr 13, 2008 | Whirlpool Gold AD70USS 70 Pint Per Day...
DeLonghi DH100P Dehumidifier Logo
224 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
