Question about Refrigerators
My fridge was cycling on and off and then just quit working completely. Should I buy a new one, or is there a fix I should learn about?
My GE refrigerator was cycling on and off and then just quit working completely. Is there something I should know or just buy a new one? Thanks! Debi
  • dorman1739 May 23, 2009
    Well, I'm singing praises! It turns out the GFC had tripped for some reason and once it was reset, the fridge worked great again. Who knew a tripped GFC would cause the motor to cycle on and off then shut down after quite some time? Not me! Thanks for your input!
  • Anonymous May 26, 2009
    where is the GFC switch
  • 159 Answers
The on and off can be a blockage in the system or the motor can be damaged
Posted on May 22, 2009
GE Harmony top load washer stops during washing cycle and display screens turns off. Does not run a complete cycle on any selection. Could it be the display unit us bad?
check the pump if thats ok you might have a bad time switch but they can be quite easy to install and cheap to buy depends on the model and were you get it
Mar 01, 2015 | GE Washing Machines
How can I fix my fridge?
think twice. You replace this, but it still is a 14 year old fridge. Next week something else can go down. The newer ones use less power to cool the same amount.
Buy a new one, you have warranty, and in its lifetime it will save you money on the electricity bills.
Jul 17, 2014 | GE Profile PSW26P Stainless Steel Side by...
The control panel quit working, the the fridge stop working completely!
you have to change out the mother board located in the back of the fridge part number wr55x10942 and it's around 150 dollars
Feb 12, 2011 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
GE WPSE4200A0WW model won't shut off or stop.
I am pretty sure it si not the pressure switch. pressure switch controls the amount of water per load. It appears your control panel has failed. You have many parts in this panel, however you can buy a complete panel and change it out.
Jul 19, 2009 | GE Washing Machines
GE fridge doors open and close
Raise the legs up on front till the machine tilts slightly towards the wall. The weight of the doors will then be shifted towards the machine instead of away from it. Only a slight adjustment is needed and should have been done by the delivery guys. A $5 tip would have gotten that done, you must be a cheapskate.
Source: I used to deliver them before I learned how to fix them. LOL
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Defrost cycle is not working on Amana model BX21Te
had similar problem with a ge fridge. remove the back panel if you can and clean out the dust and dirt. this may help, if not, your fridge may need a part such as a component board that controls the defrost cycle. that's what i had to do with my ge, it cost about $150 but i had some other work done as well. it sucks but it's a lot cheaper than a new fridge. good luck.
Nov 13, 2008 | Amana Refrigerators
Problem with ge profile fridge
sorry. ge had several fixes for this problem,unfortunatly none worked
i worked for ge and have tried everything. you have done the right thing, buy the way i have to defrost mine today!
ps make sure it is completely dry before you turn it on. for your info.
this problem started after they moved the evaporator from the rear wall to the floor of the freezer the new evaporator allows too much air flow over the fan thus your problem
Dec 13, 2007 | Refrigerators
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
