Question about EliteGroup P4S5MG/GL+ Motherboard
P4S5MG/GL+ MOTHERBOARD Will not boot up completely, locks up within 2-3 minutes of running. locks up in cmos in same amount of time, changed power supply no difference, changed cmos battery same result. need a manual
    Scholar:
  • 116 Answers
Sounds like a heat issue, is the CPU fan spinning?
Are any of the capacitors swollen?
Posted on Oct 13, 2007
Check for the cmos Jumper Setting whether the cpu speed is assigned manually, if its so check the Ram Speed Compatible with the Motherboard FSB. If its not keep the CMOS jumper setting to system defaults.
Posted on Jan 23, 2009
Not boot from flash drive
go into cmos and change it to boot up
Jan 01, 2013 | EliteGroup P4S5MG/GL+ Motherboard
Bios password reset
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip.
So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
hope this helps
Feb 24, 2012 | MSI MS-6734-10 (-6734-010) Motherboard
I changed the password on my laptop and now i cant remember it can you help me??
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
hope this helps you
Sep 12, 2011 | Computers & Internet
Please help me recovering password for WD 500GB HDD
recover your hdd using recovery software (e.g. Hiren's boot CD)
Aug 16, 2011 | Computers & Internet
I forgot my password.
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Aug 08, 2011 | Computers & Internet
Hitachi sata 120 gb hard disk lock & password
also if this is a desktop computer
Jul 29, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
Codes on how to change a password using php..
im not sure what you mean by php ??
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 03, 2011 | Computers & Internet
Hard drive locked by unknown pass word
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased:
. Hope this helps
Jun 28, 2011 | Western Digital (WD3200JS) 320 GB Hard...
Bios password wont let windows boot up
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 13, 2011 | Toshiba Computers & Internet
Securitycode lock
if you are refering to a password
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased. Hope this helps
May 23, 2011 | Computers & Internet
EliteGroup P4S5MG/GL+ Motherboard Logo
416 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
