Question about Samsung SPH-M500 Cellular Phone
Changing the amount of time the foreground is on
When my M500 is closed the date and time on the foreground screen is only on for about 10 seconds and then it goes black.  I have tried to go in under settings, but it will only let me change what the foreground is ( a digital clock, an analog clock, calendars, and others) but I can't get the amount of time to stay on.  I would actually like it to be lit as longs the phone is on
  • 1,006 Answers
Try to update with new software if it still wont work then u have a problem with ur batery
Posted on Oct 12, 2007
SOURCE:
How do i change the time or date on my eclipse g2 180 mp3
when changing either date or time
1. set the first one then hold the center button for a few seconds then release. It should move to the next column.
Dec 27, 2012 | Mach Speed Eclipse 180 MP3 Player
Need information on how to set time & date on a GE
Press and hold the STOP/SET button for two seconds, then release to access the set-up menu. The time/date setting follows the language.
The full details are in the "Changing the Settings" section of the manual (page 10 in my copy). If you need a copy of the manual, you can download one at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
Sep 23, 2011 | GE Cordless Phone & Answering Machine...
Iphone screen get dark in the middle of the conversation
Changing the auto lock setting will improve that.
  1. Click the settings icon.
  2. Click the general option.
  3. Press the auto lock option.
  4. Change the settings to your heart's desire.
The phone will dim 10 seconds before whatever the time amount selected is. For example, if you chose 60 seconds for autolock, in 50 seconds, it will start to dim.
Remember, changing that option to "Never" will drain your battery life much faster if you forget to lock your phone!
May 23, 2011 | Apple iPhone 3G
I have a alpine MRP-M500 amp connected to 2 10 inch comp kicker subs. The problem is the subs rattle and distort. The subs have been tested ok and all the wiring has been tested also ok. What could be...
Any time that there is a rattling sound from the subs, that indicates that they are probably blown. How were the subs tested ok? If the resistance of the subs is still close to OK, that is good, but it doesn't necessarily indicate that they are working properly.
Try using different subs at a lower volume, or turning down the gain slightly.
Mar 11, 2011 | Alpine MRP-M500 Car Audio Amplifier
CHANGING DATE. SET DATE INCORRECTLY WHEN USING 1ST TIME
I understand that you wish to change the date on your KODAK camera.;
Please go into the menu, camera settings, date and time.
You can also reset the camera: Take the batteries out for longer than 10 sec. reinsert and the camera automatically asks you to set date and time.
Jan 16, 2010 | Kodak EASYSHARE Z1285 Digital Camera
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
  1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
  2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
    Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
  4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
Foreground light
can i how the phone if you don't want it my email [email protected]
May 25, 2008 | Samsung SPH-M500 Cellular Phone
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Samsung SPH-M500 Cellular Phone Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
