Question about Compaq Armada 7800 Notebook
Can not get access to the BIOS setup screen
I have a Compaq Armada 7800, my hard disk crashed and I am trying to reinstall the Windows Operative system but I can not get access to the BIOS setup screen, How can I do it?
  • 1 more comment
  • dgarkie May 10, 2009
    i had a similar prob with a compac presario DT the bios screen went by so fast that i ended up having to supertap the F8 button
    i have sence recycled the monstrocity
  • dgarkie May 11, 2010
    for me i dont even think there was an F1, F8 was bios and F12 was boot
  • Frank Zhang
    Frank Zhang May 11, 2010
    why you access bios setup, are you touch F12 key to select boot sequence
  • 560 Answers
Try F1 or F2 to access BIOS, F12 to temporarily select boot sequence, you can select your optical drive so you can install new OS.
Posted on May 10, 2009
I am getting a bue screen-''unmountable boot volume'' and i dont have a disk for my compaq armada 7800
There are many reasons behind this one the data cable of the hard drive may be defective the hard drive itself may be defective or the BIOS of the mother board may be corrupted it is recommended to call a tech to resolve the issue as this is a hardware related fault.
Feb 01, 2010 | Compaq Computers & Internet
Crashed HD and now way to get to BIOS or BOOT SEQ.
When you power-on the computer, does anything display, such as the amount of RAM, or "press DEL to enter BIOS setup"?
If not, then you have a hardware-problem with your computer;
the "good-news" is that the data on your hard-drive is OK.
If you connect the hard-drive to another computer, you can "rescue" your data-files.
May 21, 2009 | Compaq Armada 7800 Notebook
Accessing bios
Some Compaq's actually have a partition on the hard drive for the BIOS. If someone
> used FDISK to remove the partition, then you won't be able to get into the BIOS
>without either re-creating the partition or by booting from a floppy with the setup
>utility on it. One of Compaq's disks will re-create the partition, but of course,
>will blow away all the data on your hard drive.
>I had to download two programs from Compaq:
>1) PC Diagnotics
>2) Setup for Portables
>I got them from the Drivers section of Compaq's site.
>This was one of the files, it is for an Armada 1750, so it probably won't work if
>you have a different machine, but will give you an idea of what to look for:
> www.compaq.com/support/files/armada/us/download/8093.html
Nov 10, 2008 | Compaq Armada 1750 Notebook
Please help me with my COMPAQ ARMADA 1700
plz check the hard disk cable if its ok then your hard disk may be bad.
Jun 11, 2008 | Compaq Armada 1700 Notebook
Install xp-sp2 on compaq e500
First tell that which O/S it had earlier coz armada e500 notebook comes with 64 MB RAM and 12 GB HARD DISK , had you upgraded your notebook with RAM AND HARD DISK .
If not then check the hard disk space you have left in the notebook.
Apr 25, 2008 | Compaq Armada E500 Notebook
Startup Problem
On the 1750 the setup bios settings are held on the hard drive, if you cant get any further I would suggest the drive is dead.
Jan 26, 2008 | Compaq Armada 1750 Notebook
How reset bios password
Yess u can rajjena .Go to the BIOS and check if u can see REMOVE OR RESTER PASSWORD!
Nov 09, 2007 | Compaq Armada 1700 Notebook
Unplugged my armada m700
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
 - Floppy drive
 - CD drive
 - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Oct 28, 2007 | Compaq Armada M700 Notebook
Compaq Armada 7800 Notebook Logo
779 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
