Printed page has vertical lines
Paper has vertical streaks
    Sergeant:
    Champion:
  • 225 Answers
Good morning! possible that your printer roller mechanism is dirty OR the printer toner ink is low. best regards
Posted on May 10, 2009
Xerox is printing pages with a red line down the left side
Streak in only one color:
Check the condition of the print cartridge, and replace as necessary.
Verify that the print cartridges (C/M/Y/K) are genuine Xerox cartridges,
and replace if necessary.
http://download.support.xerox.com/pub/docs/6180MFP/userdocs/any-os/en/user_guide_en.pdf
May 05, 2014 | Xerox 6180MFP/D Printer
White streaks and double printing
Usually when a printer can't feed paper evenly anymore, it's worn out. As long as you are using fresh paper and not over or under loading the paper tray, the rollers should feed the paper ok.
Nov 24, 2013 | Office Equipment & Supplies
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
It prints vertical lines where the text is.
check your drum unit. The toner cartridge mounts into the drum which can be permanently charged causing a constant streak to occur.
Solution:
Remove the toner and drum unit. Clean them off with a non-fuzzy non-rough cloth or paper towel. Pay particular attention to where the streaks are in relation to the toner cartridge and drum. If you clean it off and you still get streaks check whether they transfer from the toner or just from the drum.
There may be a way to discharge the drum, otherwise you need a new drum.
Feb 27, 2009 | Dell 946 All-In-One InkJet Printer
Vista for canon pixma mp140
Here's the solution from Canon USA:
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
