Ok so my hazard button broke and I super glued it in to stop the hazards and horn from constantly going off . can I fix that or did I do permenant damage
SOURCE: 2004 F150- Hazard Flashers dont work, turn signals do work
try replacing the hazard relay it should be under the dash try turning it on and off with your head down by the floorboard to pinpoint the right relay and the location. you should be able to hear it easily. hope this helps.
SOURCE: 95 GMC Sonoma --- Brake Lights and Turn Signals --- NOT WORKING
yes , i have a 96 mine done the same thing , i was removing the dash cover to install a radio accidently broke mine , i had to push down on what remained and wedged a sheetrock screw to hold it in place till i could get a new one
SOURCE: no brake/hazard lights,have running/turn signal lights
Suggest you change hazard flasher 'can' first, then go to the hazard switch. I'm betting it's the flasher can.
SOURCE: 1997 sonoma turn signal flasher
The flashers are located behind the instrument panel trim, roughly between the base of the steering wheel and the ashtray, just to the left of the car lighter. To access the flashers, you need to at least loosen the lower instrument panel trim. Just under the steering column there are two screws with star heads. One to the left of the column and one to the right. You need to remove both of these screws. You will need to remove your ashtray. On the upper left corner of the hole left by removing the ashtray is a 9/32 hex head screw. You need to remove it. Once these three screws are removed you should be able to pull down on this portion of trim under your instrument cluster. When you do this it may cause trim around your instrument cluster to loosen that you can just pop back into place with your hand. You won't need to pull down to far on this trim piece as there are still some screws holding the bottom. You should be able to pull it down far enough to see the flasher units behind and just to the left of the cigarette lighter. There are two flasher units and I found that the one on the right is for the turn signals.On the left the other is for the hazard flashers. It may be a hand scraping experience to replace the flasher but it beats paying someone to do it for you. They are easy to recognize because the are silver and round metallic plug ins. The flasher unit on the left is for the emergency flashers and the one on the right is for turn signals. You can place the emergency flasher unit into the slot the turn signal unit belongs until you get a replacement. These flasher units are pretty cheap.
SOURCE: Audi A4 2003 Alarm Problem
There is a few things to do check the door switches that control dome lights, check wire down by the skid plate when you get oil changed there is a sensor for the starter there if it is stolen the alarm will go off or just take a BAT and BEAT the living **** out of your horn and call it good like I am going to. I hope this helped or will help I recommend an aluminum bat vrs. wood
