Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Redeposits material on dishes
The dishwasher appears to clean dishes and then redeposits the food particles back onto dishes and glasses.
  • 6jsloans Dec 10, 2007
    washer redeposits food everywhere. the soap dispenser also appears gunked up with soap. dishes are hot but not dry after full cycle. anyone have suggestions.
  • dixoncrew Dec 01, 2008
    My Kenmore ultra dishwasher 665 is redepositing ground up food back onto the dishes at the end.
We had the same problem and we have managed to resolve it for the most part.  We have found that the detergent makes a huge difference.  Our experimentation found that Cascade Complete powder did the best job.  Also, our old glassware was wide at the bottom and narrow at the top which I suspect made it difficult for the spray arm to get water up there so we bought new glassware and that helped a lot too.  It still happens from time to time but it is pretty rare.
Posted on Oct 14, 2007
SOURCE:
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
Jun 29, 2011 | Dishwashers
Food gets stuck on dishes especially in the top rack.
There is a waste filter in the bottom under the lower spray arm that needs to be cleaned periodically. If you are not cleaning it, it may be redepositing food particles on your dishes.
remove and clean the filter, and see if that helps.
Nov 21, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Food particles are being thrown back onto dishes during rinse cycle and the rinse cycle is noisy.
i would suggest you dont put the food particles in the dishwasher in the first place,it sounds like you need to clean your filters out as it is a funny fault,
Apr 12, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
IT is leaving food on the dishes
You do not have to prewash your dishes before loading them. In fact, by prewashing, you actually defeat the purpose of most dishwasher detergents. These detergents are activated by the grease and oils in food and work better. You should only scrape your plates of solid materials that are not recommended to go into a dishwasher (i.e., celery, popcorn kernels, tough chunks of meat, gristle, etc.).
If you are getting food particles on your dishes, this is known as "redeposition". Most commonly it is caused by food particles trapped in the filter of the main wash pump. You will need to remove the lower spray arm and access the filter screens and clean them of all debris.
If you need further assistance on how to disassemble your dishwasher to access the filter, please post back with your MODEL NUMBER. I hope this information is helpful to you.
Mar 29, 2010 | Dishwashers
GE Profile Dishwasher not cleaning - older PDW7880GOOSS
My GE Profile Dishwasher PDW8280N00SS wouldn't clean the dishes. I found what looked like plastic particles along with food particles in the wash arm spray holes. I found that heat had warped the gray flat filter in the bottom allowing food particles to bypass the filter, and I found that the flexible plastic sump inlet was disintegrating internally shedding plastic which clogged the filter to the pump and getting into the pump. This shouldn't happen. The material that the sump inlet is made out of is too soft and porous. I noticed other components in the wash water system made from the same white flexible rubber which is an unacceptable material. I bought replacement parts at a cost of $100 for both and this has solved the problem. What's distressing is that the replacement parts appear to be made of the same inferior plastic. And I have noticed upon closer inspection that additional interior parts appear to be heat damaged (warped). This dishwasher has been used less than 4 years and problems like these in a high end dishwasher are unacceptable.
Sep 15, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dwc7400aaw maytag -glass are cloudy,groundup food particles drying to dishes & glasses,when filling makes loud high pitched sound-generally not cleaning well.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Apr 06, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
377 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
