Error when installing printer: Cannon iP4600
Hi, I was trying to install my Canon PIXMA Printer (Model: iP4600). I am using Vista as my OS. I inserted my installation CD, followed all the instructions on the disk and in the end it popped up a window saying: Printer Driver: An error occured while files were being copied. I restarted my computer and tried setting up for my driver and once again the same alert came up. Thanks.
  • 2 more comments
  • Tiffany May 10, 2009
    Thank you so much rjbeg123. That was very helpful.
    I went to the site and tried downloading the driver directly from the web instead. However the same error message still popped out. I guess there must be something wrong with my computer. I have already e-mailed Canon's support team. Hopefully they will get back to me asap. In the worst case, I'll just have to bring it back to Staples and ask for a refund or something :-(
    Thanks for helping me out once again! I really appreciate that. Just now I plugged in the USB chord which is connected with my Canon printer into my laptop and turned on my printer. Windows tried installing the driver without the installation disk but unfortunately the attempt wasn't quite sucessful so I requested Windows to look up for a solution through Microsoft and apparently they don't have an solution for me either. Instead it suggested me to go to Canon's site and contact them directly. I had a HP Printer (HP Photosmart C5100 All-in-One Printer) before replacing it with Canon and I didn't had trouble installing the printer drivers at all. Maybe the driver for HP is crashing with Canon? I think chances are pretty low right? It would be really stupid if you can only install one printer on one computer..
    Yeah, I tried it last night. The problem was under installation of drivers. And there it wrote it couldn't find the software for the driver. It shows a report was already sent out. I right-clicked on the problem and see if there's an immediate solution to it, but there's none.
    OMG, YOU ARE AMAZING :D
    I disabled user account control and then restarted my computer. Tried installing the driver from Canon's site and it didn't work at first. Restart again and it worked! My computer is a very very odd machine. I probably yelled at it too much last night. He's finally co-operating with my new printer.
    A million thanks! You're the best techie alive =)
    President:
  • 272 Answers
I would go to Canon USA below is the direct link and download the driver from there. It sounds like you have a bad disk, or it's not Vista compatible.. No proplem they are always updating drivers and have them for free. I would give you a direct link to the download but they need you to specify whether your running a 32 or 64 bit version. Click on this link select your operating system and you will be able to download and install the latest drivers and software for your printer. Here you go:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
Posted on May 10, 2009
  • 2 more comments
  • rjbeg123 May 10, 2009
    Sorry about that, In vista when you go to your control panel you should see an icon that says problem reports and solutions, it looks like a computer with a yellow exclamation mark and a green check. Try opening that, the first section of that relates to install errors and should tell you what the error is and possible solutions for it. Give that a try I'll check back and see how your doing. It might be a compatability issue with another program or Vista security as well.
    You can install a lot of printers, at work I have all of the printers and copiers on the network installed on my machine so I can test them. Did you have a chance to check the 'problem reports and solutions' icon on your control panel yet?
    Go back to the first link I sent you to . There are 4 software packages that your disc should have installed for you. All 4 are available at the site, I would try downloading them individually, and installing them. Then turn on the printer and see if you can get it to install this time. It really shouldn't be this hard! I make purchasing get hp and epson printers as they seem to be the easiest to install! If you downloaded the driver make sure you saved it in an easy place to find. Did you double click on the driver after you downloaded it? You need to as it is an .exe file it should install itself. The only other thing I can think to try is to go into your control panel, double click on your security center icon. Under other security options turn off user account control. Say yes when it asks if your sure. Now try and install. I run all of the Vista machines with it off as it frequently causes compatability and install issues. Beyond that I'd have to be at your machine to put it through the paces and figure out what the issue is. Good luck!
    Glad to help< Vista's been kickin' me around for awhile so I've come up with a few tricks to kick it back. User control has been a real PITA for me as well. Glad it worked. have a Great Day!
I have got a Cannon Pixma MP 130/110 Printer However I tried to install the Printer with the CD provided with Printer and it gives out the following error message " Your Windows Version is not...
Try downloading the printer driver from the Canon WEB site.
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload :-http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Apr 15, 2011 | Canon PIXMA MP130 All-In-One InkJet...
PLEASE HELP ME WITH ERROR 6A80[canon 4600]
first you proper installed software by original driver cd deliverd by cannon after if problem still continue then check cartridge but cartridge should be ok , specialy in cannon cartridge demo cartridge working for very short period replace new one originally cartridge, or if your printer sensor ribbon deeply scrached it should be replace.
Feb 19, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
Hi I am running Windows Vista SP2 on an HP Compaq laptop and trying to install drivers and then software for Canon Printer IP4600. Have tried from CD Rom, Windows update with printer attached and Canon's...
Try updating drivers on device manager.
Plug in your printer - right click computer (on start menu) - click properties - on the next screen click device manager - on the next screen there should be a usb device with a yellow question mark - right click on the question mark - select update driver software - ensure the cdrom supplied by canon is in the cdrom drive.
The computer should scan the cdrom for the applicable drivers and automatically install them.
Jan 02, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
How do you set up a cannon ip4600 as a network printer from the installation disc
Best would be to install on one pc and share it on the network!Good Luck!
Mar 31, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Could Canon iP4600 inkjet printer cause PC to reboot
No, please give me more details on your computer and operating system. If the computer is rebooting it's probably incompatibility in the software
Jul 20, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
E5 error
hi try to install a new driver from here http://support-my.canon-asia.com/EN/search?canonsearch=1&lang=EN&category=Multifunctional+Printers&series=PIXMA&model=PIXMA+MP160&menu=Download otherwise ur error code means The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly. Install cartridges properly. so try to clean the cartridge pinout well by using Acetone or something like that also try to clean the pinout of the cartidge mount inside the printer when it's power is off.
Jun 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Driver on original CD is 32-bit Intel compatible platforms only, and I use Windows XP 64-bit
goto > http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
Enter the Operating system.
Download the new driver
Apr 24, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Vista 32 bit with canon pixma ip4600, unable to detect printer
Try adding the printer via the Printers tab under Control Panel.
Click on Add Printer
Select Local Port: USB001(Virtual Printer Port for USB)
Wait for the Next Dialog Box to pop up and select the Have Disk Button.
Then go to where ever you have your driver located I used the one on the CD provided with printer, and follow the bouncing ball so to speak.
Hope this helps.
Seeker
Dec 28, 2008 | Canon PIXMA iP4600 Color InkJet Photo...
Canon Pixma MP210- cannon install
your canon mp210 came with 2 hardrive discs try both. If this still did not work go on to the canon website and find your model of your printer then go on drivers and downloads. find your OS
i hope this helped
Oct 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
477 people viewed this question
jasbo
jasbo
