Question about Car Audio & Video
No sound coming from my speakers
There is no sound coming from my radio speakers. Is it more likely to be the amplifer or a fuse? If it is the amplifer would any crossfire amplifer work with my 2005 corssfire coupe?
  • 63 Answers
If Theres No Sound Comeing From Your Speakers At All Fully Check Your Wires For Any Breaks Or Connectivity Problems To The Head Set Or Power Supply Also Check Your Fuses If Problem Persists Let Me Know With What You Looked At And Ill Try To Talk Your Through. Hope This Is Of Some Help To you
Posted on May 10, 2009
  • rpolk01 Jun 19, 2011
    This happened to me after I replaced the battery on my 2005 Crossfire...still don't know what to do??
I want to check my radio speaker fuse on my 2003
You have a fuse for the factory amplifier. It will be lo ated in the fuse panel.
A thumbs up would be greatly appreciated want-check-radio-speaker-fuse-2003-jjq1gbgvbnuqnoqvaolrtxpp-1-0.jpg
Sep 19, 2014 | 2003 Chevrolet Monte Carlo
No output to speekers Sony STR-DE825
Check that the mute is not on.If a headphone is plugged into the receiver the speakers will be muted.Verify the the output selector is set to the correct source.Here is a simple check.Select a strong FM radio station.Plug in a headphone.If you are receiving an audio thru the headset.Then disconnect the headset and see if the audio is transmitted to the speakers.If you still have no speaker sound check to see if the speakers have fuses which may be blown.I would try another set of speakers to determine if it's the amplifer or the speakers.The amplifer has fuses as well. Wiilbe inside if not at the rear
Oct 21, 2012 | Sony STR-DE825 Receiver
I have a 1997 Dodge Ram 2500 4x4 Diesle 5 speed manual I have a factory radio with 6 disc. changer the radio works and so does the cd changer but I get very little volume Im sure its a amplifer problem....
To determine how your speakers are amplified you will need to know what speaker package is installed.
Usually Laramie editions come with Infinity speakers.
If I remember correctly the Infinity speakers have appliers on them.
My dodge truck is a year 99 2500 series, and I have already had to replace the door speakers. I used the cheap Walmart speakers. (6x9) They fit well enough.
Note: If your truck came with amplified speakers, non amplified speakers will only push what your radio can provide it in Wattage.
May 02, 2011 | 1997 Dodge Ram
Bose radio comes on but no sound in my 2004 chevy avalanche.Sometimes even with radio off you hear a popping sound come from speakers. thanks
First Visually check all your fuses. Does rig have amp for stereo by any chance? It sounds like amp is bad and/or fuse is blown. Amp is wired between radio and speakers, and a shorted amp would make crackling in speakers when radio is OFF
Feb 26, 2011 | 2004 Chevrolet Avalanche
Hi my name is james im having trouble with my audio coming out the speakers what should i do
1. Do you have power to the unit. I assume yes.
2. Ensure the fader and balance is set to neutral to ensure you have output going to all the speakers.
3. Ensure the speakers are connected.
4. Ensure the speakers are not out of phase, if they are they will cancel each other out, and sound muted
5. Always test new model head units with a cd. not fm radio. Using fm radio on some head units will mute the sound if the station is not coming in clear enough.
6. Set your volume up a little, like on 15 or 20 (using the digital 40 level radios) (halfway in plain language)
7. Ensure the mute isnt on
8. If running through and amplifer, ensure the power, ground, remote, gain and phase are all correct.
9. Ensure rca input is going into the correct place on the amp
10. Ensure speaker output is actually connected to speakers.
hope this helps
Aug 08, 2010 | Pioneer AVIC-D3 Car DVD Player
The radio and the cd turns on but no sound comes out after having the battery replaced. The vehicle is a 05 Mercury Mariner
radio runs off two power wires, one full time power and one switched power check to see which is working. turn the key to acc. and see if power stays on with car off, check all fuses. open the hood and look at battery cables, look to see if everything was hooked up right and if there is a amplifer in your car could be a fuse on the line to the amp either next to the battery or next to the amplifer.
Feb 15, 2010 | 2005 Mercury Mariner
I'm not getting any sound from my Subaru stereo. The display is lit up and the CD player shows it's reading the CD but no sound comes out of the speakers. The same thing is happening on the radio too. Is...
no way ...not a fuse ,could simply be the arness wire in back of the radio that is louss,or the amplificator in the radio that is shut ...no way of fixing that ,
have you cheked for muting button or some kind of bluethoot systhem ??
Oct 11, 2009 | 2005 Subaru Outback
Radio works but no audio. 2005 chevy silverado
check to see if you have bose audio, it will say bose on the door panel speaker grills - if you do the most common failure is the amplifer located in the center console.
Jul 15, 2009 | 2005 Chevrolet Silverado
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
