Question about Cooktops
-F1- My Magic Chef Oven, Model # 3868XRW keeps beeping every 30 seconds or so and the digital screen reads: -F1- any ideas?
  • 473 Answers
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board.  I would need the entire model # on sticker on the oven to see what parts are on this one.  If the touch pad is separate it will have a ribbon that goes from it to the board.  Unplug that ribbon, if the code goes away then the touchpad is the problem.  If the code stays with the ribbon unplugged then the control board is bad.  Make sure power is off to unit when touching anything!
Posted on Oct 12, 2007
SOURCE:
Magic Chef, F-1 code?
This might help... http://www.appliance411.com/archive/25036_magic_chef_f1_error_and_slow_to_heat.shtml
Jun 20, 2013 | Cooktops
I have a magic chef oven the model number is 439w 3w, i need new burner knobs and oven thermostat knob, i need help trying to find them. Can you please help.
Hello, Thank You for using FixYa. I will be helping you today.Assuming the model is correct here you go http://lookup.bellparts.com/lookup/13830/76035
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Magic Chef 30 in. 8241RT Gas Cooktop
Magic chef oven: lights hard but when lit comes up to or near temp sputters and will not come back on???
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 14, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
Model CGC2430 Magic Chef Cooktop ignition keep clicking
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Jan 01, 2010 | Magic Chef CGC2430 Gas Cooktop
All 4 burners keep firing although the knobs are in the "off" position
It actually stopped doing it all by itself while we were waiting for a solution.
May 16, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
MAGIC CHEF GAS STOVE/OVEN TURNS ON & OFF
your technical support is horrible after being left on hold for so long and being told to pay 10.00 just to ask a question is poor business.
Nov 19, 2008 | Cooktops
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Jul 13, 2008 | Magic Chef 30 in. 8241RT Gas Cooktop
Magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
Mar 12, 2008 | Cooktops
Cooktops Logo
350 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
