Question about Curtis DVD1045 DVD Player
Curtis 1043p dvd
Dvd was working ,turned it off and several days tried to turn it on but not
successful.  Checked power cord ,fuse ok. switch ok
  • jazmainia Dec 07, 2007
    i have recieved a curtis dvd5028 player for x-mas about 2 years ago.and it has been working fine ever since then. But i have come across some problems. what had happend was that over the past two months, my dvd player wouldn't respond after i turned the power on. So i left it on for two days and when i came back home from school, i was like yay it works!!☺ So i turned it off again. And a few days later i went to go turn my dvd plaver back on and now all i see is vertical red lines on the dvd player screen(not the tv screen, the dvd player's where u aim the remote at) please help ASAP
    ♠jAzMa!n!a♥
Srry about all the comments i didnt mean to post soooo much
Posted on Dec 07, 2007
My Curtis DVD1041 Player will not turn on
May be this li know to the online manual will help.
Bob
Curtis DVD1041 Instruction Manual
Mar 28, 2014 | Curtis DVD1041 Player
Magnavox ZV450MW8 will not turn on
if no power indicator check for broken power cord, if ok at this time you will need to remove the cover of the dvd player to access the power supply.then look for blown fuse or any burnt parts here.
Sep 22, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
Wharfedale LCD2710HDAF no power to tv, checked cable and changed fuse a few times, new power lead? or is this a common problem?
Hi.
The power cord must be checked using a multimeter. The test is done reading impedance (ohms) between plug's prongs and contacts to TV power board.
If the power cord is OK and there is no power, then the problem is the power board inside the TV.
Regards.
Ginko.
Dec 04, 2011 | Televison & Video
I have the power cord dvd cords and cable cords plugged in and there is no picture the tv wont turn on it should turn on but it wont it wont even show that its off
Have you verified #1 that your outlet is putting out 120 VAC? Have to checked input power fuse inside chasis? What about a stuck power on switch? Unplug all access. except the TV and try powering it on.
Jul 31, 2009 | Dell W3000 30 in. HD-Ready LCD Television
When I turn my unit on, it will turn itself off in a few second.
have you checked to see if any of your speakers are shorted out? the rt2870does have a self protection system in place such that if theres too much power being drawn from the system or if a short occurs it will shut off. or the switch that powers the sub may have gone bad so try disconnecting the sub and see if that helps. i have the same system and i had the same problem and i had to replace the onboard sub-woofer power switch.
Mar 15, 2009 | Audio Players & Recorders
Motor won't turn on
Hi , Try to check with multi tester the power cord ,test the two tips of male outlet switch on tested read the continuity /if not reading ,pulout if push type /if permanent open cover below test the test the cord inside to the male plug if does not response cord is problem,check also fuse test both end of fuse not reading fuse buste then replace thats all goodluck.
Nov 12, 2007 | KitchenAid KSB5 Professional Stainless...
Canon IPixma 4200 Won't Power On (occassional)
Go on an elimination hunt. Try connecting to a new power outlet altogether. If no go, try turning off and removing all cords, usb etc, reconnect. Then try uninstalling and reinstalling the printer to see if this corrects it. Post agian if no good.
Aug 23, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Troubleshooting
Is it plugged into the power ? A fuse could be blown. A power supply failed. Short happened in the load on the power supply. All of these will stop the set from coming on and several more. You need to have it checked out. Stargazer
Aug 12, 2007 | Curtis CM19102 19" TV
Curtis DVD1045 DVD Player Logo
201 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
