My RCA Television Model# TR29M62 switches off within 5secs after power button is switched on.
There is some kind of short circuit to any of the component/s at its circuit board. Short-circuit protection circuit [built in] energizes and shuts off the TV each time you switch it ON. The fault location to this kind of trouble is a skilled work and not a user repairable one. It is best to contact any service technician. Its main power supply regulator section circuit should be troubleshooted. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
google.com/+GopakumarGopalan
SOURCE: rca television
Pry the black cover off the top where the buttons are (make sure tv is unplugged), then take circuit board out (remove ribbon cable first) and get it replaced.
SOURCE: TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
SOURCE: when switching off the television with the on/off switch the red
That just lets you know that it is in standby mode..
SOURCE: MY BUSH TELEVISION MODEL IDLCD27TV006 HAS POWER TO
Just had same problem today. Presumably you've seen the more recent solutions on other web sites regarding replacing the C330 capacitor. It appears to be an over-temperature issue. After trying to press all sorts of buttons, removing plug for a time, leaving off for a time, it just started to work again but I don't know how! The tv stands beside a radiator and this may have been on for a while and caused this problem. Will monitor situation before diving into its innards.
