Televison & Video Logo
c
chris Conrad Posted on Dec 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Surge protector was blinking. smelled a little electrical burn odor. pluged tv directly to wall..all I hear ia a click noise..nothing lights up . help!
officechcik
Level 2:
Scholar:
New Friend:
  • Expert 65 Answers
  • Posted on Dec 02, 2013
officechcik
Expert
Level 2:
Scholar:
New Friend:
Answers
65
Questions
0
Helped
30520
Points
119
The surge protector has likely committed suicide... or died by homicide. In other words, it may have done its job, or been fried trying. Either the breaker/fuse inside melted by design due to a surge, or it died.
A surge protector is only designed to protect you from many small/everyday surges, or ONE BIG ONE. The cumulative wear of small surges will eventually kill them as well. They don't last forever, and some experts recommend replacing them every 3 years or so for safety/performance.
Some surge protectors have a reset switch or a replaceable fuse, but since you smelled something burning, I highly recommend tossing it in the garbage (if not still on fire, hee hee), and get a new surge protector for safety. Your house is worth the $25+. If you have had any other electrical issues in your home lately, get an electrician to do a quick safety inspection as well. Be safe!
PS: Not all surge protectors are created equal. Look for one that has "lighting protection" and costs at least $20-25 , or you likely don't have decent protection (the ones I buy are usually $30-$35, but I watch for sales and keep an extra on hand). Never overload a surge protector or wall outlet. Read the manual for the total watts,etc. supported. And don't expect to collect on the $50,000 equipment damage guarantee some surge protectors promise.
3 Related Answers
Anonymous
  • Posted on Nov 08, 2007
SOURCE: green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
A
Anonymous
  • Posted on Nov 16, 2007
SOURCE: TV won't come on, power clicks on then off
Thanks for the insight!
Anonymous
  • Posted on Dec 22, 2007
SOURCE: tv wont turn on the timer/standby light lickers
Open up the tv. On the boards that have connectors, de-attach all of them, one by one. Use a can of "duster" to clean out each receptical, then re-attach each piece. Do this to each and every connector on the boards inside. This should solve the problem.
SAMSUNG TV UN65MU8000F KEEPS BLINKING SAMSUNG SMART TV ON THE SCREEN .THE RED LIGHT WAS ON AN BLINKING FOR A LITTLE BIT BUT STOPP. THIS HAPPEN DURING A LIGHTNING STORM.WHAT COULD IT BE
if you did not have all the electrics pluged into a power strip with a surge protector then it is toast I have one in every outlet and I have battery backup on all the computers and even tvs. so I have never had a problem when the lighs go out or any surges within the house. I had a small tv once and did not have that setup and it fried it adn one of the computers later on. so now I have them all protected. it is cheaper to get the surge protectors then to replace the computers and or tvs
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Tv just makes a click noise when pluged in
remove the back and look for any swollen or blown capacitors. it sounds like your power board went out
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
2helpful
Blinking red light in front of tv (lamp) and noise coming from tv as well.
The Lamp light of the TV blinks when the Lamp of the TV requires replacement. The model # of the user replaceable lamp block is XL-2200. You can download the manual of the TV by clicking here. Refer to page # 76 of the manual for further information. Follow the steps below to perform a power reset first:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Flashing Lamp light, no picture KDG42WE655
The Lamp light of the TV blinks when the Lamp of the TV requires replacement. The model # of the user replaceable lamp block is XL-2100U. You can download the manual of the TV by clicking here. Refer to page # 16 of the manual for further information. Follow the steps below to perform a power reset first:
2answers
KDF 50E2000 WONT POWER UP POWER LITE BLINKS RED 3 TIMES THANKS
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
3helpful
RED LIGHT KEEPS BLINKING..WAS LIKE A POWER SURGE THIS MORNING..I UNPLUGED TV OFF MOSNTER SURGE PROTECTOR..CAME HOME AND PLUGED BACK IN...TV RED LIGHT TV REC STILL BLINKING
Surge protectors aren't perfect... If the surge was big enough and long enough then it can cause problems. Most manufacturers have on-board protection as well. That's not perfect either. Often the surge does nothing more than confuse the microprocessor (computer) that controls all aspects of your television. The fact that the red light is blinking means that your set is trying to protect itself. This can happen for one of two reasons. Something in the set has failed. Usually the power supply inside the set possibly also a trouble in the scan section of your set. These are normally a shop repair. The other thing is when the microprocessor is confused it will do nothing further until it's reset. To reset the processor simply unplug the set from the wall and wait 10 minutes. Plug it back in and if it works then happy viewing. If it doesn't then you will need a repair.
If is a failure caused by a failure in the grid that delivers power to your set then you are usually able to file a claim for the repairs. Contact your local power company. explain what happened. If it's their fault then usually they will pay for a repair. I know the PG&E does.
Zashiban
I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
2helpful
Ihave a sony KP53S75 TV there was apower surge and now there is no picture. The red light blinks 4 times can anyone tell me about this?
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
