Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Timer blows Fridge quit working. Got the timer out and looked at it and there is a black spot on it where it has blown. Purchased another timer and put it in and the same thing happened, the new one blew also, in the same place.
  • 473 Answers
Sounds like something is shorted to ground.  My guess would be the defrost heater which is behind the back panel in the freezer.  Take off that panel and unplug one end of the defrost heater.  Check from the end you unplugged to ground (frame) with an ohm meter and if it shows resistance then the heater is your problem.  Heater may even be obviously broken. If shorted then replace heater and timer.  Let me know what you find.
Posted on Oct 12, 2007
SOURCE:
Hi, my Stoves 720EF is 16 years old. We have had no problems until today when we noticed that the main oven was not heating up. The light and fan come on, but no heat. The timer is not set. We have...
Peter
ISOLATE MAINS POWER BEFORE WORKING ON ANY APPLIANCE
It sound like an element problem, but, you need to investigate, before we can go ahead to define the exact problem, the varistate control is working because the fan operates.
Remove the ovens, remove the rear and may have to remove the top, or sides, remove the bottm fan, you should be able to vue the element, look for Black Grey burnt blow out, not carbon or food spots, if you see or feel a rough spot on the element, it probabily is blown. Replace heating element. Seach in whitegoods.co.uk for part, you will need model and serial numbers.
Hope this has been helpful
John
May 17, 2011 | Stoves 720EF Electric Double Oven
Refrigerator not cold and ice keeps building up in lower freezer unit all over .keep defrosting and runs good and then same problem.
Your defrost timer is bad or your heating element. The defrost timer in newer models is inside the fridge side under the plastic cover in the back or if you have a light and dial themostat dial in the top centre its there. The timer will be black with a shaft in the center that a flatblade screw driver can turn. Turn it slowly one click at a time until the fan and compressor kick off. (the fan in the fzr will kick off also) You can hear audible clicks but go slow the defrost mode is just one click of the dial and it may take you a few minutes to hit the spot. When the fan and compressor stops wait about 3 minutes and listen to the freezer you should hear hissing and popping ice sounds if you dont you need to defrost the freezer and take the back off so you can see the cooling coils you may have to defrost it even more once the coils is exsposed. You will see a black heating element (or a glass one with an element inside rare) this element will be attached to the cooling coil and on one end of it will be a nikle size disc this is the defrost limit it keeps the heating element from getting to hot for to long. If the element is bad it will usually have a spot in it blown out and burnt. You can ck the element with an ohm/volt meter these can be picked up at any hardware store for 5 to 15 dollars. It will come with directions on how to use it. But either your defrost timer,element,or thermal limit is out. If you have any trouble let me know and I will walk you thru it. good luck and respect the electricity and unplug the fridge before testing parts.
Aug 16, 2010 | Amana Refrigerators
Dometic Refrigerator Model RM 2820 Stopped working purchased 5-4-2004 . Tom Collins
Hi Tom,
If your fridge quit working altogether, check your DC fuses in the fuse box, as well as the back of the fridge under the black plastic cover (3 amp). Though the fridge uses LP and 120vac to cool, it is controlled by 12 volts.
Apr 30, 2010 | Dometic RM2620 Refrigerator
Unit stopped dead.no lights in both fridge and freezer. Does not run. checked power plugged into another circuit still nothing
The exact same thing happened to me. An LG service tech was sent to my home, only to tell me that he couldnt fix the problem.. a blown fuse. He said the entier fridge had to be replaced. You would think a blown fuse owuld be an easy fix, but evidentally not. LG did replace the appliance but after it was replaced they told me theyd only guarantee the new fridge for 90 days. After that, my extended service plan would come into effect. Good thing Id purchased that plan because my 90 days was up last month & now my ice maker has quit working. I will never buy another LG product!
Oct 19, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
Ge profile brita 18 bm black purchased in jan/06
Having the same problem. apparently this is just a horrible fridge... unfortunately no solution for ya
Jan 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
D52W19 blowing fuses????
Anytime they blow the AC fuse you have other part/parts shorted,ck fuse resistors big white resistors on same board and hori output or any shorted diodes.
Nov 30, 2008 | RCA D52W19 52" Rear Projection Television
The refrigerator is not keeping tempurature. Freezer is working fine
Either the freezer fan has stopped blowing air or the defrost timer has stopped and the airways to the fridge are clogged with ice. Only the freezer gets cold in a refrigerator. The fridge part gets cold by cold air being blown through air passages from the freezer. Good Luck!!
barneyluc
Oct 03, 2008 | Amana Refrigerators
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
