Question about Palm Treo 500 Centro
My palm centro does not turn on and the red light stays on
  • yeahman_gosh May 25, 2009
    i have the same exact problem my keyboard wasnt working so i took the battery out put it back in and the red light just appeared.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
Hello halvarez,
Have you tried a soft reset by removing the battery and leaving it out for a couple minutes then reinserting it ? The Centro should run as normal after removing the battery and reinserting it. All your information is retained when you perform a soft reset.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Posted on Aug 24, 2009
SOURCE: Palm Centro locked
If you forget the password, the only way to get back in is to perform a "hard reset." Performing a hard reset causes you to loose all data on your phone unfortunately (numbers, texts, and all). Hopefully you've sync-ed up your data on your computer recently.
To perform a hard reset, do the following:
1 - Remove the battery cover.
2 - Take out the battery.
3 - Put the battery back in. An orange Palm logo will appear on your screen.
4 - While the logo is showing, press & hold the Power/End button until a black status bar appears on the screen, fills completely, and then goes away. Then you can stop pressing the button.
5 - Next on your screen will be a prompt to erase all data. Press up to say Yes.
6 - Next select your language and you have an empty phone to start a new. If you've previously sync-ed up your data, you can sync up now and add it all back.
Posted on May 31, 2009
SOURCE: locked out of my palm centro
How do I recover my old passwoed?
Posted on Nov 21, 2008
SOURCE: My palm centro kayboard light wont come on.
Have you tried the option key + menu key? It turns dims the screen and toggles the keyboard backlight on and off.
Posted on Dec 07, 2008
SOURCE: My palm centro began hot
The problem is from the connectors on the bottom getting wet, slightly moist, oily from your hands touching it or just plain dirty. This sends an incorrect signal to the phone that makes it think the cable is attached and requesting what ever action is initiated by pressing the button on the cable, which is set by default to initiate hot-sync.
Two things can make this problem bearable or even resolve it:
Clean the bottom connectors to resolve the incorrect request for action being sent and/or reprogram that cable button action to do something different, like go to the phone's home screen instead of initiating hot-sync.
I take a packaged alcohol pad like they use at the doctors office (not a cotton ball, the fibers get stuck in the grooves and deposit too much alcohol in the phone) and wipe the bottom connectors down really, really well. then let dry. two or three times of doing this _always_ fixes the problem for me. I let a lot of alcohol get in there but the pads don't contain all that much extra which is why you should use the pads to keep from damaging you phone! (they are cheap at wal-mart.)
In the meantime, reprogram what the phone does when it receives (or thinks its receiving) a signal from the cable button press. On the centro, go to Preferences --> Buttons --> HotSync, then set the app you want to activate. I use "phone" so when the problem reoccurs, my phone keeps sending itself to the keypad, not the long long process of activating and canceling hot synch.
You will have to manually launch the HotSych application from the home screen when you synch if you keep that button the same or you can just change it back to the default when resolved.
Hope that helps!
Toni
Posted on Aug 13, 2009
SOURCE: Palm Centro - continous Syncing problem, now phone is dead
This happened to my palm centro and i fixed it myself. :) Maybe it will work for you. What i did was take out the battery and so the phone is completely off.. then take a tooth brush with rubbing alchohol on it and scrubbed the bottom part of it that the hotsync cord goes into.. I thought this may just mess up my phone more but i plugged it back into the power cord, turned it on and it worked just fine!! Seriously, try this out. It brought me so much relief!! And chances are you either got some **** stuck up inside there, or you got the botton part wet. Hope i helped!!
Posted on Sep 05, 2009
My palm centro will not turn on the red light just blinks and occationally it does come on
Hello abevagota25,
A flashing red indicator light (upper left-hand corner) occurs when the Centro is connecting to the the cell phone network. The light will continue to blink until it gets a strong enough signal to make a good connection. Try turning the phone on from different locations to see which one makes a good connection
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 02, 2010 | Palm Treo 500 Centro
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
Treo very hot and not turning on
I think your battery failed. When the red light is on that indicates the unit is trying to charge the battery, and it usually will get a little warm, but if it's really hot then a cell in the battery has probably failed.
You will need to take it to a dealer and get a replacement battery. (I've had to replace the battery in my Centro twice since I got it a year ago!)
Sep 23, 2009 | Palm Treo 500 Centro
I tryed charging my palm centro with the USB cord and the red light came on but it didnt charge what do i do?
your laptop is plugged in right? I would check the battery options on your laptop.
Aug 30, 2009 | Palm Treo 500 Centro
Red light staying on but phone not on
well when my light turns red it usually means my phone is dead
Aug 09, 2009 | Palm Treo 500 Centro
My palm centro was hot cyncing intself
I just googled this issue b/c my daughter got a hold of my phone and somehow (as only an 8 month old can) hotsycned my phone. O
ut of total frustration at the thought of having to replace my phone, I took the battery out and left it on the counter for about a minute. It works fine now.
Aug 04, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Red light stays on
you will need to go into your menu under the system or display and turn off the LED indicator.
May 28, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
My palm centro wont turn on. it has the red light on but its not on the charger
hey i had the same problem but just a tad different, my phone just wouldt turn on in general so i plugged in the phone and just started messing with the keys, i dont know if that will help but its worth a try
Jan 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Blue tooth for a palm centro
the problem was that you must open the headset after you hold the talk button till the light comes on then flip it open and the light stay on so that the phone can receive the signal.
Jul 09, 2008 | Palm Treo 500 Centro
Palm Treo 500 Centro Logo
1,406 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
