My ibm t42 screen goes dark shortly after bootin up
  • Frank Zhang
    Frank Zhang May 11, 2010
    could you try connect to a EXT VGA minitor see what happened?
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 10, 2009
My computer (IBM Thinkpad t42) keeps going from an IBM screen to a blue error screen over and over. Then it goes to a windows error recovery screen. Please help!
One of those screens will provide you with an error code or a more detailed description of why it crashed. Please provide that information...
Aug 15, 2011 | Computers & Internet
My fn key and home for making screen light bright isnt working can any one tell me is there any other way to make my screen light high???please help its so dark
You should try to determine why your Fn keys are not working... just to make certain, the Fn+Home key will increase brightness and Fn+End will decrease.
You can try the blue IBM-Access Key. In the Configure tab, you can manage the display settings.
If you cannot see your display because it is too dark, try attaching an external monitor via the vga connector.
Aug 09, 2011 | IBM ThinkPad T42 Notebook
It is stuck in a loop the screen goes from the IBM logo to a screen explaining that windows didnt start successfully to windows starting up to a blue error screen and then repeating.
You can have your T42 working again by doing the following:
1. In the windows didnt start succesfully screen choose to boot in safe mode with command prompt
2. when it starts, enter the command chkdsk (that means check disk)
3. accept all the changes done by running the command above and restart your laptop
4. everything should be OK now
Aug 07, 2011 | IBM ThinkPad T42 Notebook
Dear Sir, Screen of my IBM T42 goes black while I use that... then I have to power off manually. please help
When it goes black, shine a light on the screen, can you still see your desktop very faintly?
Mar 18, 2011 | IBM ThinkPad T41 Notebook
On screen display of volumn keys on IBM T42
check it on the IBM site for the programme
Sep 03, 2009 | IBM ThinkPad T42 Notebook
IBM t42 Display problem
Sometimes there are keys are your laptop that adjust your settings.
If you know which keys you can hit the fn key simultaneously.
If your not sure go on line and you should be able to find a site that will tell you how to adjust your screen.
In search type your laptop model then type display settings
Jan 12, 2009 | IBM ThinkPad T42 Notebook
Fonts revert to defaults after change
go to desktop properties than appearance than change color schme, font size , windows button
Jan 08, 2009 | IBM ThinkPad T42 Notebook
Laptop screen gone dark
I had a similar problem on my Fujitsu-Siemens Lifebook C-1020 and I had to replace both the C/C inverter that the CCFL lamp. Easy to find/replace the inverter (only take care of input/output plugs), tricky to find/replace the CCFL lamp (because of diameter, lenght and toxic Hg content).
Zpp
Have fun!
Mar 09, 2008 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
454 people viewed this question
David Payne
David Payne
