Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
How to reformat the usb 2.0 flash drive (product name CRUZER MICRO)
  • diosoroy May 10, 2009
    yes i did already what you taking about but still not working the procedure, i'll do the step like this; go to drive it shows, then right click on the drive and drill down to format.
    but when i press the start button to begin the format process it seems doesn't work, it shows like this; Windows unable to format so what i suppose to do? the file is raw.
    yes i want to keep my u3 program, yes i did also this steps, but the result is this; the type of the file system is raw. please use the /FS switch to specify the file system you wish to use on this volume.. so what means this /FS? and what's gonna be next?
    President:
  • 788 Answers
I have one of these as well. All I did was go to the drive it shows in My Computer and right click on the drive and drill down to format. That will do it.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
Posted on May 10, 2009
  • 3 more comments
  • John Snow
    John Snow May 10, 2009
    I did not want to give you inappropriate information, so I will try to justify my help and see if I can help you resolve this issue. I did not know that you already tried that. I have one question for you. Do you want to keep the U3 program on the flash drive or do you want to get rid of it?
  • John Snow
    Here is something that I have done before.
    1. Open MyComputer and find out which drive the Cruzer is mounted as. Mine was E:
    2. Go to start then go to Run. Then type in CMD.
    3. [my Cruzer mounted as E:] ...so at the command prompt, I typed "E:"
    4. Once in E:, I typed in "format e:" (enter)
    5. It'll fight with you a bit...and it will probably tell you that E: is busy, but it can override the 'busyness' to format.
    6. When the format command asks you to override, you say Y[es] and it invalidates all active handles to E: then starts to format the drive.
    7. It will take quite a while if you have an 8GB like I do...be patient.
    I hope this helps and the information is no longer inappropriate for this situation.
  • John Snow
    I have looked at the SanDisk web site and they have a format utility and a utility to install the U3 Launch pad if it is removed. So you should be safe.
    Here is the Sandisk link
    http://www.sandisk.com/retail/driverdown...
    The format utility is under OEM -Driver Downloads
    This should take care of the format.
  • John Snow
    The /FS is a switch to force the format.
    With the following options.
    format e:/fs:ntfs, or format e:/fat32
    My ScanDisk U3 is formated using fat32.
  • John Snow
    John Snow May 12, 2009
    Just wanted to know if any of this helped you. asnowman
Help How can I unblock my sandisk cruzer
Dear Customer, Plz Flow this instruction i think solve you problem.
Reformat the drive:-
  • Right-click the SanDisk flash drive within "Computer" and select "Format..." Enter a name for the drive, select your desired format (FAT32 is typical for flash drives). Click "Start" to format the drive. This, unfortunately, will erase everything on the drive. Any data contained will be lost along with the password protection. Once reformatted, the drive will be fully accessible.
Sep 12, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to reformat a flash drive
Hi jabbbbbb6,
The Cruzer Micro is a flash storage device that connects to your computer's USB port. It comes in various sizes and fits on a keychain. If you want to erase the drive, you can perform a reformat from within Windows' Disk Management utility. After you reformat the drive, you do not need to reinstall any drivers because Windows automatically detects the device.
To Reformat, please follow the instructions:
1. Insert the Cruzer Micro to an available USB port on your computer. Right-click "Computer" and select "Manage." Click "Disk Management" under "Storage" on the left pane of the window.
2. Right-click your USB drive on the list of drives and select "Format." Select a name and file system type for your drive.
3. Click "OK" to reformat the drive. Click "Start" and "Computer" to access your drive.
Rate this accordingly.
Hope it helps.
Thank you for using Fixya.
Oct 06, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have nothing on my scandisk, but it is showing it is full. What can I do about this?
I would try reformatting it. Go to My Computer and rigt click on the thumb drive ( e: for example) and select format
Mar 01, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Cruzer scan disk can not be recognized by pc
if not recognized or virus attacked your flash disk, just reformat it. but beware you will lose all your files when reformating.
Dec 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Cruzer Micro 4GB USB plugged it, light on, but shows an empty file in windows with capacity of 0bytes Also shows a CD drive (the one that U3 runs) which says nothing is in disk drive.
It is likely an issue with the filesystem. The FAT filesystem gets easily corrupted. If that's the case, reformatting it with FAT32 should help. But remember - reformatting erases all the data, so don't do it if you have anything important on the drive!
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
Oct 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
1gb cruzer micro
This is caused by 1 of 2 problems:
  1. Your flash drive is corrupted in some way, forcing the computer to reformat it before you can use it.
  2. The flash drive was formatted for a specific device (like a piano) and was made only for that device.
  3. Your PC incorrectly recognized it
  4. You do not have the correct drivers installed.
If you have problem #4, you can go onto google and search "1 gb cruzer micro drivers".
If you have problem #3, try plugging your flash drive into a different USB port.
If you have problem #2 or #1 (Which it most likely is), then you should try or buy a software application such as PC Inspector, to recover those files. Then you may reformat the flash drive.
However, I found that sometimes, just restarting the computer, and inserting and re-inserting the flash drive sometimes does work. But that's not guaranteed.
Feb 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
286 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
