Question about Bosch Brute Breaker Hammer 11304
Bosch Breaker Hammer Service Kit Install
I've completed the seal service kit, reset all parts but my question concerns the included grease in the service kit. There is an upper gear section and the lower piston area. I s the grease split between these 2 areas or only in the upper gear drive behind the paper gasket? Thanks
  • 2,176 Answers
The grease in the upper drive area used to be a purple looking grease and the grease in the barrel was a different color and weight. If you ordered the rebuild kit with the O rings and bolts I would use it in the barrel (light film coat on the parts )
Posted on May 23, 2009
Bosch gsh 10c is not hammering
Likely the hammers are broken inside the drill.
Oct 07, 2016 | Bosch Drills
How much grease goes in a bosch 11335k?
I believe this tool takes 225 ml of grease, but I would strongly recommend installing a service kit #1-617-000-702
The service Kit comes with grease and all the normal wear parts (highlighted below in black circles) Service Pack 1617000702 for Bosch Power Tool eReplacement Parts
Jun 16, 2014 | Bosch 11241EVS SDS-Max Rotary Hammer
How to lubricate electric demolition hammer
Only lubricate is not enough,the kind of grease is brand and breaker type dependent , but a consumables kit and a condition that the machine that front that the striking pin in the front air and lubricant is closed in terms of oil seals etc completely closed has very high priority otherwise it is only momentary, because all O-rings, etc. are to fast getting hot again a rapid solidification and its leaking again , and premature all kinds of rings are hardened again, therefore there must be a service (maintenance kit (spare parts) are used A NOTE a rotary hammer is not a demolition hammer and there is often more wrong with and most times too expensive to service in proportion to hidden defects with respect to the new price it than a heavy breaker
May 26, 2014 | Hammering
How to repair bosh 11316evs
Purchase a service kit # 1-617-000-190
This will have all the normal wear parts including brushes & new grease.
This is a fairly easy hammer to rebuild - make sure you thoroughly clean all the parts, install new rings & grease - the kit comes with a parts breakdown to help. Service Pack 1617000190 for Bosch Power Tool eReplacement Parts
Apr 15, 2014 | Bosch SDS - max Demolition Hammer 11316EVS
Bosch demo hammer model 11304 034: is it necessary to service the oil or lubricant in these electric hammers. currently no problems exist.
Your hammer has brushes that push away from the armature when they wear past a certain point. At this time you could buy the service kit that includes most parts including grease to get your going again. The link below will give you an idea of the parts included in the kit. If however you store your hammer more than use it, you could pull the lower half and lube it. You can just order Bosch grease. If your hammer is used constantly / heavy / hot climate, you can increase the life of the tool by greasing more often. Most damage is done by using long cord or generator with too high or too low voltage. Good luck
http://www.ereplacementparts.com/service-pack-pi-81738.html
May 28, 2011 | Hammering
How much and what type of lube do i put in the area where the piston and crankshaft are located?
Best practice is to purchase service kit part # 1617000050 . It is available from several outlets including link below. The kit includes items that need to be replaced at time of lubrication.
If you do not want to purchase the kit then use Bosch 1615430015 Hammer Grease 15oz
Mar 08, 2011 | Bosch Brute Breaker Hammer 11304
Purchased a brute hammer at a garage sale and it is missing 1 of the 3 springs from the area where bits attach. Is this an easy fix and or expensive Thanks Mark
Parts are easily available for your hammer. Check on ebay or www.toolpartsdirect.com. There is a service kit available # 1617000050 that includes set of bolts, orings, grease, brushes etc. After the service kit is installed your hammer will be ready for serious work . This kit does not include springs (#3614640501 each, uses three ). Good luck ~ greatest electric hammer ever made!
Nov 10, 2010 | Bosch Brute Breaker Hammer 11304
How do I drain the gear oil from a Bosch Brute Jack Hammer
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Won't Hammer!!
try repacking with grease as per service kit 897
http://www.islandhirecentre.co.uk/docs/spares/B10201.pdf
thats the drawing for it
if that fails then its a replace all seals/o'rings i'm afraid
a fairly big job btw
Jun 12, 2009 | Hammering
Bosch Brute Breaker Hammer 11304 Logo
1,352 people viewed this question
Top Bosch Hammering Experts
John Trevino
ken skalski
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
