Question about Panasonic Televison & Video
POLAROID TLA 04641C AFTER VGA PLUG TV WON'T WORK
POLAROID TLA 04641C I PLUGGED FOR THE FIRST TIME MY LAP TOP ON TO THE VGA INPUT, TV SCREEN SHOWED A SIGN THAT READ SOMETHING LIKE: NO SIGNAL, TV WILL TURN OFF. THEN IT TURNED OFF AND NOW IT WONT TURN ON ON THE ON/OFF SWITCH OR W/REMOTE. I ALSO TRIED UNPLUGGING THE POWER AND PLUGGING IT BACK AND IT JUST WONT WORK. THE RED LITTLE LIGHT ON FRONT IS ON. WHEN I PLUG THE POWER CORD IT MAKES THE REGULAR CLICK NOICE ONCE.
  • thomasinasin May 11, 2010
    please help, when I turned on my polaroid flat screen it says no signal vga input
  • Maxine J Feb 10, 2012
    I am having this same issue. I unplugged and try to turn back on but nothing happens. The red light comes on and I can hear the click noice once but the tv will not turn back on. Does anyone have any info on what I should do now?
I am having the same problem.. did u ever got it fixed?
Posted on Aug 07, 2010
  • rxbagain Nov 29, 2010
    Hi
    Have you ever found a solution for this problem? I'm also experiencing it after I turned of my laptop while the tv is connected.
    Thanks.
  • RUBYGLOOM166 Sep 14, 2011
    I HAD THIS SAME ISSUE AND I JUST UNPLUGGED ALL OF MY LAPTOP FORM THE TV AND UNPLUGGED IT WALKED AWAY DID SOMETHING CAME BACK PLUGGED IT BACK IN TURNED IT ON AND CHANGED THE SETTING BACK TO MY CABLE AND BAM IT WORKED AGAIN
Polaroid tla-04641C blue screen no signal for air/cable every other input works what could that bee
Check and replace its tuner. It is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Timeslide" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Polaroid Televison & Video
I was using the tv as a monitor on a laptop. When I restared the laptop, the tv screen showed multiple imagmes on top of one another. When I turned off the tv, it would not show a power light and will not...
I've got a Polaroid TV and have had nothing but issues with it. Try unplugging it and leaving it for 10 seconds then plug it back in.
You might also have pressed the PIP/POP (Picture in Picture / Picture on Picture)button, which basically tells the TV to display one input on top of another. I could have the name of the button wrong but it's something similar. If you get it to power up again, try hitting that button till it looks "normal" again.
Thanks
Moza805
Aug 30, 2011 | Polaroid TLA-01911C TV
Need an owner manual for TLA D4641C
Thought that was going to be easy but Polaroid no longer have the manuals available for download on their site. Typical.
Anyway, here's a direct link to download your user manual (free):
http://www.hdtvreview.com/pdf/polaroid-tla-04641c-manual.pdf
Click the link, PDF will open in a new window. From there you can view, save and print. Please note your model number is actually TLA-04641C.
Please rate my solution if you find this helpful. Thanks.
Oct 16, 2010 | Polaroid Televison & Video
I have a 46'' Polaroid HDTV model TLA-04641C
It hasn't been 'unplugged' until you have let it stay that way overnight. There are components that need to discharge and that can take hours. You wrote 'standard sounds;' did this mean audio or something else?
If you have normal audio but no identifiable video, then the backlight or the inverter for the backlight has failed.
If audio is present, try looking at the screen from several angels to see if you can identify some ghost-like video. If so, then the above suspicion is pretty much confirmed.
I hate that the modern sets seem so prone to failure, it isn't a good trade-off for the increase in quality of the results. Most of these are not poor engineering but the effort to build them with the cheapest possible parts inside, often only saving a few dollars, but ruining their reputation.
Mar 10, 2010 | Televison & Video
How do i get my laptop screen to show on my tv. I have the VGA cable hooked and on the VGA Input?
on your laptop keyboard, Hit the function key+ f8 to toggle between laptop screen and monitor. If not f8 then there should be a pic of monitor or crt/lcd.
Dec 30, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Unable to program remote on my TLA-04641C.Can't find the code
i have a book with the codes what is the product and name
Dec 14, 2009 | Polaroid TLA-04011C 40 in. LCD TV
I plugged for the first time my laptop on to the VGA input tv screen showed a sign that read something like: no signal, tv will turn off. then it switched off and now it wont turn on on the on/off switch...
There is a button on your laptop for switching from laptop screen to external screen, This button is usually in the top row of special function buttons, did you press that as it will tell your computer you are connected to another monitor. Also some times you have to leave the monitor off for about 5 minutes so it will reset itself.
Oct 09, 2009 | Televison & Video
Tla-04641c won't turn on
my tla-04641c stoped taking commands the day after using it with my laptop and was stuck on so i unplugged it and now it wont turn on when i plug it in the red light comes on and i hear the relay click button nothing happens when i push the on button. any suggestions? i pulled the power board and nothing "looked blown"
Aug 23, 2009 | Televison & Video
Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
Feb 23, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Televison & Video Logo
964 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
