Question about GE WBSE3120B Top Load Washer
Removing front panel of a ge washing machine
We can get one side disengaged but not the other. The putty knife is not working
    Sergeant:
  • 306 Answers
You have to be missing a screw head there somewhere that is still holding out.
Posted on May 10, 2009
GE Washing Machine WWSE6260B1WW won't spin out water makes a rattle noise
use a putty knife to remove the front panel , you can remove it by pushing the putty knife into the 2 black tabs between the top and front panel. from there you can get to the drain pump . inspect by taking the hoses off the pump and remove debris. If nothing found replace the pump. hope this helps, let me know
Feb 19, 2013 | Washing Machines
How do you remove the front kick panel
Here are the steps.Hope this helps.
Insert a putty knife between the top of the kick plate and bottom of the front panel near the center of the washer, if you have an older model top load washer. Move the putty knife blade in and out in that area until you feel an obstruction. The obstruction is the kick plate retaining clip
Press the putty knife blade over the spring clip until you feel the clip disengage. Let go of the putty knife and grab both ends of the kick plate with your hands. Pull the kick plate away from the washer
ift the front of the washer with help from a friend, if you have a front load model Whirlpool. Slide a block of wood under the front of each side and gently lower the washer Remove the three hex head screws on the bottom edge of the washer kick plate with a Phillips-head screwdriver or nut driver. Pull the kick plate away from the washer.
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
How do i remove the lid on a ge profile harmony washer?
Use a putty knife to remove the front panel first/
The putty knife will insert between thr top of the lid and the front panel about 2 inches in from each side.
The panel will pull forward then up to remove it.
Then remove the screws holding the lid down.
You may have to open the control console to remove the lid.
Apr 03, 2011 | GE Profile WPRE6100G Top Load Washer
Side check valve on drain tube, how do you get i
ok ge first get a putty knife and use along the front uper edge ull be able to pop the pin on each side pry forward with your fingers while using the putty knife on the front lid
Jul 22, 2010 | GE WDSR2080D Top Load Washer
How do I remove the front to check the insides??? I think the belt is broken
Place a flat blade metal putty knife on the right and left sides of the front at the top where the front panel meets the top panel. There is a metal clip on each side that locks the front in place. Push in with the putty knife between the top and front and you will feel these springs. Press in one at a time and pull out gently on the front and it will come off.
Jun 27, 2010 | GE WBSR3140DW Top Load Washer
How do I remove the front panel of a ge profile washer wprb8050d
That may not be possible; many units have connected front and sides that are removed as one piece by removing hardware in the back and inside the washer.
Oct 24, 2009 | GE WPRB8050D Top Load Washer
Removing front panel on GE washer
If the machine was made AFTER Jan. 1, 1995, than there are two "squeeze" point on the bottom of the front panel one is on the left and one is on the right you have to "squeeze" these points to loosen the panel, than on the top of the panel there are two clips that hold the panel from the top.
Jul 13, 2009 | Frigidaire FWT449
Front panel removal
use a small putty knife move in 4-5inches from each edge of the frount push in the putty knife to the top release clip . it will feel springy when you have found the clip. push in the putty knife and pull out on the side of the panel, do the same process on the other side and it is loose
Apr 12, 2008 | GE Profile WPSR3120WWW
Removing top cover to access switch
You have to pretty much use a putty knife to remove the front panel. Insert the putty knife into the edge of the front panel where it meets the top lid panel about and inch or two from the sides. One clip on each side. Push in the putty knife and give a little pull on the front panel repeat step for other side. That should get you into where you need to be.
Hope this helps you out. Feel free to ask any more questions about this if you run into anymore issues.
Mar 22, 2008 | Kenmore 22422 Top Load Washer
Will not drain
If your GE Washer is like mine all you need to remove the front is a 2 inch putty knife. Insert it in the seam between the top and front panel about 6 inches from the corner. You will find a clip there. Push the clip backwards with the putty knife while pulling gently on the corner of the front panel, the clip will come loose and the front panel will come froward on that corner. Repeat the procedure on the other side and the front panel will come right off. To put the panel back on just insert the bottom of the panel in the bottom clips and snap the top right back into place. This makes access to the inside of your GE washer a breeze. Before doing this always disconnect your electrical plug.
Dave
Jan 13, 2008 | GE WBSR3140DW Top Load Washer
GE WBSE3120B Top Load Washer Logo
437 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
