Question about Sewing Machines
Machine is threaded but thread not sewing into material, just holes!
Bobbin has thread, needle is threaded, can bring bobbin thread up but they are not connecting! I run machine "sewing" but no thread is sewn in material
  • 25 Answers
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
Posted on Jun 02, 2009
  • dorothy randall Sep 05, 2013
    the bobbin is right and the needle is right but the machine isnt sewing the cloth
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Why does bobbin thread keep snagging?
increase the needle thread tension up a bit as it is too loose to pull the bobbin thread up properly
keep adjusting until both threads are at the middle of the materials being sewn
Mar 25, 2016 | White Sewing 1418 Mechanical Sewing...
HOW TO THREAD THIS MACHINE
Search the internet for:
Make + Model + the word "Manual"
Remove the thread. Install a brand new needle.
Be sure you are using thread that is compatible with the needle and fabric being sewn.
All About Needles
Raise the presser foot and rethread from the beginning.
Make sure your threading is following the correct thread path and the bobbin is loaded and threaded properly in the bobbin case.
If it continues to malfunction, it may need service.
Feb 24, 2016 | Sewing Machines
Birdnesting with every size needle and thread
tension is not set properly .possibly both upper and bobbin
Dec 14, 2015 | Sewing Machines
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Needle timeing is out
The timing is set at the factory. If the threads are not hooking together, then perhaps try one of three things.
1. remove the thread, and run the machine at full speed for three minutes or more. This warms up the hardware, loosens gelled up oil, and get's all the parts in allignment.
2. (and 3.) Check the thread tentions. On the top thread, it will be a dial with numbers, over a spring and two plates that the thread runs through. On the bottom, it's a tiny screw on the side of the casing that the bobbin sits inside.
If the machine sews loose threads, then tighten these, a bit at at time, and if the machine jams up with a knot of thread at the needle, then loosen these. I believe that if the sewn threads are loose at the top, the bobbin tention neeeds tightening, and if the sewn threads on the bottom are loose, then the top tention dial needs tightening.
Cheers.
Aug 22, 2009 | PfaFF Creative 7570
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer 15 thread breaks and doesn't sew
if the upper needle thread is breaking adjust the thread tensioner if the bobbin thread is breaking adjust the bobbin tension screw on the bobbin case
Feb 16, 2009 | Singer 3343 Mechanical Sewing Machine
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Sewing Machines Logo
680 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
