Question about Refrigerators
Refrigerator is not cooling
Amana refrigerator side is not cooling, model sqd25mb4w, we cleaned the coils and took the part off the back at the bottom and cleaned there also. My husband says the compressor is running. Don't know what else to look for.
  • 3 Answers
Not sure 100% but try and changing the thermostat control.
Posted on May 10, 2009
Freezer freezes but frig wont cool amana with freezer on the bottom
I couldn't find a repairman so I pulled the big thing away from the wall, took off the bottom front plate and the bottom rear plate and unplugged the big beast. Then using a refrigerator brush and a vacuum I carefully cleaned all the dustballs from the coils on the bottom. Then plugged it back in and in about 3 hours it was cooling normally again on a "4" setting.
Jul 13, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Our side by side refrigerator/freezer is not cooling properly
first try to clean the condenser coil, it is under the bottom of the unit,blow out or vac out the coil.
check to see if fan in freezer is running or if there is ice on the evaporator coil inside freezer.
Sep 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have a 10year old Amana 25cu SRV26V side by side and our freezer and food area is not very cold. The freezer side is only 20 degrees. Both sides have been turned up to 7 as high as it can go since...
Hi: It's a sealed system so if you need a recharge it will be expensive. You mentioned that the "air filter" in the back was clean. Do you mean the panel at the bottom of the back of the refrigerator? The coils are on the bottom (parallel to the floor across the bottom) and have to be clean. If you haven't done this; remove the grill and vacuum the coils. It's best to use a coil brush to get to the very back. A refrigerator coil brush is available at Lowes or Home Depot. I use an air compressor to blow them out. Then I have to dust the house. If the coils haven't been cleaned this will cause what you described. I hope this helps, Jeff
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
May 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Topr of Refrigerator too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 03, 2009 | Amana ARB8057CSL Bottom Freezer...
Amana bottom freezer refrig runs at maximum coolness
Thanks for your inquiry. I think I may have fixed it. I unpluged it and took everything out of the refrigerator and freezer, cleaned it thoroughly inside and out and unscrewed the back wall inside the freezer. There was a huge ice buildup on the coils so I let it sit for 12 hours like a defrost. I turned it back on and it seems to be working fine. It is not running constantly and is maintaining about 5 degrees below. If this doesn't stay working, I guess I have to call a repairman.
Feb 14, 2009 | Amana ABB1927DE Bottom Freezer...
GE Refrigerator does not cool anymore
my amana SXS was not cooling properly. I took off the cover inside the back of the freezer to see if the defroster was working. it was so I timed the cycle. It was about 50 minutes. I decided that it was staying on defrost too long and too often. I replaced the defrost timer and the thermostat(since I bought both for about 40 bucks.) Previously, I had cleaned the coils underneath with a special 'refrigerator coil brush' from Home Depot. ($4) But that alone didn't fix it . works like new now with new parts.
Dec 21, 2008 | Amana SXD524VW Side by Side Refrigerator
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
