Question about Sport & Outdoor - Others
Sled has no spark have changed stator,coil,cdi, looked for broken wires, did not find any, still no spark, sled is a 1993 arcticcat, need help to get spark
  • 122 Answers
Have you checked the kill switch maybe shorted out inside,
Posted on May 11, 2009
What wires to test coil and stator. no spark.
how to fix no spark and wire pit bike - YouTube
? 4:59
https://www.youtube.com/watch?v=YX8WRLN5gZ4
Nov 25, 2013 - Uploaded by coryncheryl1
how to fix no spark and wire pit bike. coryncheryl1 ... Chinese Quad 110cc wiring hack making SPARKS !!! No ...
GY6 150cc Ignition Troubleshooting Guide: No Spark? - BD ...
www.buggydepot.com/.../gy6-150cc-ignition-troubleshooting-guide-no-...
May 27, 2014 - Stator (6th winding and trigger pickup module); CDI unit; Ignition coil; Spark ... to check for voltage at the two primary wires of the ignition coil.
Trouble Shooter Guide for NO-SPARK Chinese Engines
www.kazumaracing.com > ... > Chinese ATV Service Manuals
Number 2 is the ignition coil and that is easily found because the large wire and cap ... The final third component is the stator magnetor or magnetic pickup coil.
My vehicle has no spark. How do I test the stator ...
support.familygokarts.com/.../21258173-My-vehicle-has-no-spark-How-...
Apr 11, 2012 - 90% of no spark is caused by the CDI Charge Coil in the Stator. ... Thestator is located on engine side housing, where a 5 wire unit is coming ...
Bad Stator Fix - Instructables
Jan 06, 2016 | Motorcycles
Help have no spark changed cdi ,coil,spark plug, stator all new
Fuse, wire connection, Corrosion. All connections bright metal?
Mar 08, 2015 | Motorcycles
I have a apachi 100cc quad no spark have changed stator cdi &coil no spark?is there 12v going to cdi unit
check continuity in low tension wires, I had a vespa that had a broken wire, INSIDE THE PLASTIC COVER, took ages to find the problem.
Oct 13, 2014 | Motorcycles
No spark on kawazaki kl250 a3 1980 model
Sounds like all there is left is the plug wire from the coil - but it's probably a single unit - coil and wire w/ plug boot.
All that comes to mind is grounding. With a VOM make sure you have a ground. Also look further up the chain - follow the wiring the CDI unit plugs into for breaks. Headlight gets brighter when kicked over ? Follow the wiring to it's termination points, loose plugs etc.
Single cylinder engines vibrate an awful lot, with that in mind look things over. There is a chance the no spark condition is a product of an unrelated failure - ignition system could be fine. Check the stator coil for an open circuit where it should be closed.
Besides checking wire and plug condition, cleaning and tightening grounds. The stator is the first place I'd check.
Be careful and gentle, the coil wires are very fine and as such break easy. A shorted winding will show continuity but not generate power, a web search should give resistance ranges of the coil assy.
Too low fail/Too high fail ranges.
My brain is picked out....Hope it helps you.
Sep 02, 2014 | Motorcycles
No spark on 110cc chopper four stroke what wire is for the spark
The blue with white stripe will go from stator to cdi box. Then black with yellow stripe goes from cdi box to coil will give you spark. If u have no spark and u u haven't changed cdi box or checked coil I'm going to bet that's ur problem. Hope this helps.
Apr 13, 2014 | Golden Technologies Companion II Travel...
Cdi box, I keep blowing them after installing i get about 5 minutes and then lose spark to 2 of the 3 coils on my 2005 Yamaha Vector. Help
I had the same problem with my 2006 Vector. Blown 4 CDI units. Changed out complete wiring harness and Stator, new plugs, Carbs. We narrowed it down to the coils. They were for an RX1 (based on the part number). swapped out with OEM vector coils. installed new CDI.. Sled is running flawless now.
Jan 03, 2014 | Motorcycles
No Spark, No Power coming from CDI to coil
Check the wiring on the connector plugs make sure all the wires are the same color on both sides, red to red blue to blue and so on. I had the same problem After replacing a stator and just plugging it in,after two weeks a new cdi and coil i noticed there were two wires transposed.
Aug 22, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
My Rm 250 wont spark need to know the volts from stator to cdi plug. Got brand new cdi, stator , rotor and pick up coil but it still wont spark.
The Voltage From The Stator To The CDI Should Be Around 40 Volts(AC) At Cranking Speed. Be Sure Your Meter Is Set For (AC) Not (DC). The CDI Changes The (AC) Input Voltage To (DC) Output Voltage To The Primary Terminal At The Coil. An Electrical Shock Hazard Exist If Stator Voltage Is Checked With Engine Running. Always Perform This Test At Cranking Speed (R.P.M.) For SAFETY. 120 Volts (AC) Can Be Present With Engine Running.
May 22, 2011 | 2003 Suzuki RM 250
Hi i have a 1997 yamaha 350 warrior i have no spark to the spark plug what could be
hello, you probably need to have your stator checked out, sometimes the pickup coil in the stator will go out, also you can try ign coil, the one spark plug wire is hooked to,warriors are bad about cdi going out, mine would idle, would not rev up, would bog down, source coil in stator probably needs to be checked also..
Feb 27, 2010 | 1974 Yamaha DT 360
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
