Question about Texas Instruments TI-83 Plus Calculator
An "Invalid Dimension Error" on my TI-83 (not plus)-- Please help!
So I am trying to graph a regular linear problem into my calculator using the "y=" button, but when I press the "graph" button when the formula "abs(X-3)" (or any formula, for that matter) is typed in correctly, I get this weird error: Invalid dimension. I know that happens when something isn't typed in correctly, but no matter what number/formula I try to graph, it does the same thing!
Please note that directly before this, I had deleted old info on my date tables (press STAT, then EDIT)... don't know if this is at all helpful.
If I need to erase any of the memory of anything, which part do I erase? I already did the "clear entries" option, but that had no effect.
Thank you so much for your help,
Taylor
I'm having the same problem and I tried turning off one of these stat plots but turns out I don't know how to do it, or how to tell if I did or not. Help please?
Thanks
Posted on Jan 08, 2008
Thanks so very much for the help!!!
Posted on Sep 08, 2008
Solution #2 worked for me..thanks
Posted on Jul 15, 2008
Press 2nd Y= and look to see which one is on and select it and and highlight OFF
Posted on May 01, 2008
On of the stat plots is turned on and there is no longer any data to plot.   Turn off stat plot and your graphs will work.
Posted on Oct 16, 2007
SOURCE:
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
I keep trying to graph a linear equation, but when i push graph it says "err:invalid dim" and i have tried making my zoom different but that still doesnt work. whats wrong?
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Oct 31, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
May 17, 2010 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus calculator does everything it is supposed to do except that when I go to graph something it will not appear as a graph, but the table does show the points. Instead it says "EER: INVALID DIM"
Turn StatPlotsOff
Press [2nd][STATPLOT][4:PlotsOff][ENTER].
Calculator answers DONE.
You can Clear All Lists:
Press [2nd][0] to access the (CATALOG) of commands.
Scroll till you reach ClrAllLists
OR
press [PGRM] to jump to the first command in CATALOG that starts with C an then scroll to ClrAllLists
OR
Press [2nd][+] to open mempry Management and select [4:ClrAllLists]
Command echoes on main screen.
Press [ENTER]
Draw your graphs now.
Mar 16, 2010 | Texas Instruments TI-83 Plus Calculator
Having problem with ti 83 calculator everytime i graph it read error invalid dimensions
You must deactivate the statistical plots. If you do statistical graphs, the graphing is reconfigured in a way that happens to be incompatible with regular fuction graphs.
  1. To deactivate the statistical plots.
  2. Press [2nd][Y=] to access the (STAT PLOT) menu.
  3. Press [4:PlotsOff][ENTER].
  4. Calculator displays Done.
  5. You are ready to draw the function graphs.
Feb 15, 2010 | Texas Instruments TI-83 Plus Calculator
INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-83 Plus Calculator
Can not use graph function
How do I fix my Ti 83 calculator's window range error and do the graph?Because without that fixed I can't do my graph atall.
Oct 19, 2008 | Texas Instruments TI-83 Plus Calculator
Graphing
You're probably getting a dimension error trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Dec 04, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
1,964 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
