Question about Uniden Radio Communications
I can turn it on, seems to work but draws no power. palomar 250 linear
4 Suggested Answers
Gavin93
  • 66 Answers
SOURCE: will 25 amp power supply pull 250-linear?
Yes it could, but... but it also depends on your antenna, what antenna are you using. Do not upgrade the power of your radio unless you know your antenna can handle the output power.
Posted on Oct 13, 2008
  • 5 Answers
SOURCE: Palomar 150watt bi-linear amplifier for c.b. radio-SHORTED
turner dm 7800 base mic wires came away from the ciciut board where do they go? black and white can you help.
also wiring for astatic d104-m6b mic to lincoln can you help please
Posted on Aug 04, 2009
SD Tech
  • 14553 Answers
SOURCE: I just purchased a cobra 29 LTD Classic mobile CB radio.Pro tuned high performance Mosfet Final I have a palomar 450 LD mosfet linear.will i have any problems?
Not if the power output from radio to amp is set correct and the jumper for coax is correct length and there is absolute perfect match between them and the antenna used. Afterthought: also the amp better be connected to something big enough to power it.
Posted on Apr 29, 2012
How to repair a palomar 450 fet. Ld amplifier.
sniff around inside ,see if there is the smell of burnt wire or other componants.If it turns on see if there is a componant that starts to smoke.If it does change it and see what happens.this is called trouble shooting.
May 15, 2014 | Palomar Redman Cb Stop Hd 450-fet Hd 10...
How do i know if my palomar 250 is a high drive or low drive amp
If it is made by Palomar and it is a small amplifier, you can bet it is a low drive. Check those transistors. It could have the new Mosfet 655's in which case definitely low drive 3-6 watts input max.
Mar 30, 2014 | Palomar 250 SSB/AM Linear Amplifier for...
How many fet tranistors are in this unit and what is its max amp draw.?
There are 5 transistors in that unit that you are asking about. The amperage draw is about 50 amps
May 23, 2013 | Palomar Redman Cb Stop LD 450-fet LD Low...
Need to know how to hook a palomar 450 HD to a connex 3300hp
If its in a car or truck use heavy gauge wire to power it. I use a 3ft jumper between the radio and amp. Should use a grounded antenna system. Not a "MAG MOUNT" type. Those can "feed back" rf to your radio and cause problems. If using in the house, a large power supply will be needed.I own a palomar elite 400 hd.It uses every bit of my 30amp power supply. Your hd amp should like the hp radio.
Dec 04, 2012 | Palomar Redman Cb Stop Hd 450-fet Hd 10...
Apr 29, 2012 | Cobra 29 LTD CB Radio
I hooked silver streak 250 linear to my cobra 29 lx not working
how is the radio getting out without the 250 hooked up?
Feb 19, 2012 | Cobra Radio Communications
Can't find a free manual for Palomar 300A Linear
You can download a Free manual from the following link.( http://www.cbtricks.com/Amp/palomar/300a/index.htm ).Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 09, 2011 | GPS
My palomar 150's relay will key as soon as you turn on the power. Plus, it has 6lq6 tubes in the final?? Aren't they supposed to be 8950's?
Nope, 6LQ6's are the tube used in most all Palomar CB linears. Most tube type linears of that class have one 6LQ6 driving two or three 6LQ6's. As far as the T/R relay keying as power is supplied, you have an electrolytic capacitor shorted in the Carrier Operated Relay. My advice: get a pro to fix it, as there is 800 to 900 volts DC at a quarter of an amp on the B+ circuit, which is more than enough to kill you if you make a mistake. Too many Hams and CBer's have died that way, I do not want you to have the same accident. Find a reputable repair guy, then pay the price. It's safer that way. Good Luck,
Longshorts.
Jul 15, 2009 | Radio Communications
Owners manaul
Hello there:
if you go to www.palomar.com and look for the user manual they will have it there ok
best regards mike
Jun 29, 2009 | Midland LXT310 2-Way Radio
Will 25 amp power supply pull 250-linear?
Oct 12, 2008 | Radio Communications
Radio Communications Logo
59 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
