Question about Rowenta Compact Steamer - White
Rowenta Clothes Steamer Parts
I am trying to locate a replacement hose for the Rowenta Clothes Steamer model #GS4010. Any ideas where I might find one? Thanks.
5 Suggested Answers
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
wizzard8955
  • 18 Answers
SOURCE: Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Posted on Mar 06, 2009
SOURCE: I have a Rowenta Garmet Steamer (Commercial) and
I have an 580 or is it 9850 stemagenerator, and having trouble with getting the steam, what should I do.
Posted on Jan 30, 2010
rickead1
  • 1998 Answers
SOURCE: MY problem seems to be
Steam irons need a certain amount of mineral in the water for them to operate properly, but too much mineral, iron, or organic matter can be disaster. the loss of steam is from usually from a barrier or o-ring or some sort of insulating material it has to be sealed because if it is not the the steam will not build up the pressure required for adequate cleaning power is your iron leaking any water anywhere? if you have a water leak try to seal up the leak if you have any further questions please message me back and please remember when our chat has concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Posted on Jan 08, 2011
How to take hose off rowenta professional garnmet steamer
http://laundry.manualsonline.com/manuals/mfg/rowenta/rowenta_iron_product_list.html
Aug 13, 2014 | Rowenta Commercial Garment Steamer - White
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Jul 08, 2014 | Rowenta Commercial Garment Steamer - White
Rowenta pressure iron and steamer model DG5030? We have purchased the iron and cord, now we need to assemble the part.
Google Rowenta and go to their website, they will have parts diagrams and wiring diagrams. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does.
Apr 30, 2014 | Irons
Need Replacement Support Pole for Rowenta Commercial Steamer
According to eReplacementparts the DC0084 part you're looking for is not available for retail sale. They do however inform that that the part is avaiable for sale via Rowenta Service Centers. You can find a list of these Rowenta Service Repair Centers by state, here. I hope this helps & good luck!
Nov 07, 2013 | Rowenta Irons
Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
May 19, 2010 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
On and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Jun 10, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Compact Steamer - White Logo
373 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
