Not able to read on my laptop ,but used to be able to!
I have an iomega 500gig external hard drive ,it used to be readable to my hp dv6000,no it does not show up in my devices,it powers on alright but does not read usb wise,its also powered by an outside source,please help
  • Anonymous May 11, 2009
    no because it worked fine before,i might have accidently removed it without ejecting it properly,i`m sure this can make it malfunction!,any ideas?
  • 51 Answers
  1. Maybe you need to restart your computer and try to add hardware in control panel.
  2. try to unplug and plug again your usb connection to your hd and computer. There's some possibility that your usb cable or something relating to it is error.
  3. Is it need a driver?. If so, install the driver.
Posted on May 10, 2009
I have a dell laptop and a HP desktop computer, and a 1TB Iomega external hard drive. THE PROBLEM..the video folders/files can be accessed on the laptop but not on the desktop ? the folders are empty
it might be that the files are hidden and the option on the desktop to show hidden files is not enabled.. Try enabling hidden files and folders. Start--Control Panel--- Folder Options---View and then enable hidden files and folders.
Hope it helps,
Regards
Dec 29, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
I got an iomega HDD 500gig eGo black belt external drive. I used it on a PC and copied the files i needed. I then used it on my macbook pro and was able to copy files both to and from the drive. Now,...
There could be several problems going on here. Try this first If still unsuccessful you may need to run chkdsk in windows (XP or 7). This will unlock the protection bit on the ntfs file system and the disk should be fine. If there is a problem chkdsk will tell you. Also always remember to eject or safely remove external hard drive.
Mar 08, 2011 | Computers & Internet
I have a white light on my iomega external harddrive. My computer does not recognize it. Is my data recoverable?
There is a chance that the only thing that isn't working on the external hard drive is the actual controller of the enclosure. What you could try doing is opening up the external hard drive to get at the actual drive that's inside. Go online and look for something called an IDE to USB adapter. They are usually relativly cheap, 10-20 bucks. This will plug into the back of the hard drive and then to the computer with a usb cable. See if the drive is readable. or if you have another open SATA port in your desktop computer, just try connecting it as a secondary hard drive. See if it will read it.
Mar 04, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Trouble Saving to my Iomega External Hard Drive
Some versions of xp like to set permissions excessively, check security settings
Mar 14, 2010 | Computers & Internet
Dropped an Iomega 500gig external hard drive...
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
That clicking sound that you are hearing from the Hard Drive is coming from the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Nov 20, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
How To Practically Store items into my Iomega external hard drive
ok, for starters copy the whole folder that you have pix, doc, mp3s etc and paste to the external hd....now for itunes change options of storage to the external drive...............as long as you just checked the info is really on the external...you can than delete it from the laptop............for limewire, bearshare or whatever software you are using in options you will be able to switch where you wish to store or download to....note do not sync ipod..........
Jan 01, 2009 | Iomega Silver Series 320GB 3.5 External -...
Iomega 500 Gb external hard drive - won't allow transfer of large files
well..allowing is maybe close, but this is most likely a bandwidth from the laptop to the external drive..how do you have them connected? USB Ethernet? for that type of file size, you may find Enet to be the best, or USB 2.0
check your computers warranty here 4 FREE
Mar 10, 2008 | HP Pavilion dv6000z Notebook
No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Jun 21, 2007 | Iomega (33090) 250 GB Hard Drive
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
