Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Power requirement to identify the right transformer among many
I disconnected my power supply and it got mixed up with zillions of others. What is the voltage requirement for the freeagent Extreme so that i can identify the right supply?
  • 5,660 Answers
Output voltage is 12 volts at 2 amps. 24 watts.
See if it looks like this,
http://cgi.ebay.com/12V-AC-Power-Adapter-For-Seagate-FreeAgent-Pro-drives_W0QQitemZ260396021307QQcmdZViewItemQQimsxZ20090419?IMSfp=TL090419153008r30934
Posted on May 10, 2009
Why wont tv turn on today worked fine yesterday? powers up but shuts right back off.
This is a general answer to your question:
Your TV is shutting down because it is consuming too much current from the internal power supply. The power supply has a protection cct
to protect your TV from further damage. If yo have any technical background, then you can follow these simple steps to troubleshoot your TV fault with the aid of a schematic diagram. Let us revise what you need for your job:
1- You need a schematic diagram for your TV model
2- You must be very careful when dealing with powered equippments
3- You need to prepare all the required tools to start your test and repair
4- You must be very confident that you are able to do the job using scientific steps. We all have done many mistakes but at the end we became experts in our fields. Please remember the fault is hidden somewhere and you are going to dig it out.
Let me start now:
-Disconnect any device connected to your TV
-Plug your TV to the Main
-Power on your TV, If the fault is still persisting then check the timer setting of your remote control or take the batteries out. Restart your TV again and if the same problem appear then we need to start our repair now. I personally advice you not to do any think if you don't know what you are doing, but if you want to learn, then do the followings without powering your TV.
- Disconnect your TV cable from the main
- Place and secure your TV on a clean wooden bench.
- Remove the back cover carefully
- look at the boards and identify which is which and compare it with the technical diagram of your TV.
- Identify the power supply section. Remember that 50 % of the TV faults are within the power supply and the rest lies in different area. Furthermore, many faults occurs due to bad soldering, sparks,loose connecters, metallic debris, excessive heat and bad ventilation.
Now if you have identified the power supply board(SMPS) which is very easy to find, disconnect the output jack and test each of the male and female jack pins with the ground. Use an AVO meter (put the selector to ohms) to check for any short cct with the ground. Remembr that there are some pins connect to the ground in both jacks. If you find any thing abnormal then compare your findings with the diagram. Alternatively, you can power your TV and measure the voltages at the output pins of the power supply and compare your readings with the service manual, but please be very careful. Again remember that switch mode power supplies (SMPS)
can work with a range of voltages 90VAC-240VAC, so if you have a step-down transformer from 220VAC to 110VAC, then it would be great and more safe when conducting your tests. In this test we can isolate the fault if it is in the power supply or in a different place. Also remember that your AVO (DC voltage) readings would appear higher than normal because we have isolated the load.
If the power supply was perfect then we are sure now that the problem is somewhere else, but in certain and limited cases some SMPS cannot provide the required power to the load due to internal changes and shifts in the values of the components in the loads and the power supply. In this case you need more experience to identify the source of the problem.
We have now finished from the power supply, however in the old TVs there is another power supply source which is the line transformer. This one is very simple and I am going to discuss that later.
Aug 15, 2014 | Televison & Video
Why is my Sharp Microwave Drawer KB-1614LS not heating?
You should check for 3 volts on sec coil supply for magnetron but do this check with the hv capacitor and hvr disconnected if 3volts is present , most probably your magnetron is deffective, replace it with the same type
May 13, 2014 | Sharp Microwave Ovens
Does a ATX power transformer makes the difference of watts of a power supply unit of a computer? Exactly I am planning to improve performance of my pc's ATX power supply unit. Trying to attach another...
NO NO NO... PC power supplies are switching supply's. The transformers use high voltage to drive other components. Increasing the power out of the supply will require you to upgrade the power supply to a higher wattage output.
Oct 23, 2013 | Microsoft Computers & Internet
Power supply humming
I think you have a 110 volt machine on which you are using a step down transformer. If so it seems that the voltage from the transformer is high or the current factor requirement is also insufficient . which can produce the hum or heat. Make sure the voltage is steady or else you will need to use a stabilizer or a proper power supply that is actually catering to the requirement of the machine. You have not mentioned the power factor of the machine and i suspect that the power supply used externally is insufficient.
Sep 27, 2013 | Siemens Washing Machines
Drh55cg no heat appears to be no voltage at a small transformer secondary connects to gas valve there seems to be many safe guards
Since you have confirmed that the step down transformer is open, it is imporrtant to disconnect the secondary lead to confirm . If so identify the volatage to the valve and use a simialr voltage to be connected to it. If the fault clears then you can change the failed transformer.
However it is important to check the voltage to the other input areas so that the valve is opened so as to adjust the heat.
Use a multimeter to check, use a variable power supply to be bridged across the faulty output power.
Jun 13, 2011 | Kitchen Ranges
Getting an error display as "Push power protector" in my Sony Home theatre - DAV DZ777. what is the solution.
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
Jan 21, 2011 | Sony DAV-DX255 System
I have two ir security cameras. When it gets dark enough to require the ir to kick in, it does and then tries to go back to "day" (color) mode. It then recognizes that there is not enough light and the...
You don't mention if both cameras are malfunctioning. If so, yes it is a power problem. Each camera needs additional amperage when it switches from day to night mode. The power source is probably fine during daytime hours but can't supply the demand when the ir's kick in at night. If your power is being supplied by plug in transformers then purchase a new one with the same voltage rating (most are 24VAC) but a higher Volt/Amp rating (amperage or current). If one transformer supplies both units then purchase another identical transformer and power each camera separately. If using a power supply (transformer and power supply board) you are most likely running your cameras at 24VDC. Again, purchase another power supply with the same volltage but a larger continuous amp output. Hope this helps. Let me know if I can be of further assistance.
Jul 07, 2010 | Toshiba IK64DNA IR Day/Night Camera
HP 4070 Doesn't Power Up
Power requirement per HP specs is 12VDC @ 575mA 6.9w. My scanner and power supply shows 12 VDC @ 1250ma.Over double the power going in that required. No wonder the fuse blows and you have to buy a new scanner because you can't identify or get a replacement fuse. I would suggest you confront HP and have them supply you with a new scanner.
Aug 07, 2008 | HP Scanjet 4070 Flatbed Scanner
Won't power on after local lightning strike
with a lightning strick any thing can go. check diodes, dc fuse regulator and while U are at it check the horzontal output transistor
Dec 09, 2006 | Sanyo DS32830H 32" TV
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
540 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
